(It have a 1W Led but it's not working anymore... so I Improvised one Haha)
18650 Battery of 4.2V (I have not measured the Usb Output but is 4.2v directly)
I Want to know it I can make it a Serial Battery to have 8.4v
(Yep, Paint for Quick things Haha)
Aaaaaand the really "Want to know thing"... I Can still use the Usb Output/input for charge the batteries? I gonna use the Power directly with a switch before the usb output but I want to use the Micro Usb input for Charging the batteries...
If the batteries are equal (and has close to same charge status when you begin) it is OK to connect + to + and - to - (paralell) and charge from 4.2V (no more than 2A)
It they ar connected in series |-===+||-===+| you use 8.4V (max 1A)
knut_ny:
Stop !!! if a cell tends to be warm.
Damn, Sorry, I'm try to say I Want to conect it in series Haha
no, you can't . You won't get the needed voltage from the usb charger - you could even damage the electronic charger, which might not like the extra volts on its output (depends on how it is designed )
knut_ny:
thats 24V in your picture.. Go for 8.2v .. 8.4V
I know, It's just a Example.
alnath:
How I can make it Work in that case without damage it? :C
