little hep with button and led program
turn on a LED when the button is pressed and let it on
until the button is pressed again
int pinButton = 8;
int LED = 2;
int stateLED = LOW;
int stateButton;
int previous = LOW;
long time = 0;
long debounce = 200;
  pinMode(pinButton, INPUT);
  pinMode(LED, OUTPUT);
  stateButton = digitalRead(pinButton);
  if(stateButton == HIGH && previous == LOW && millis() - time > debounce) {
    if(stateLED == HIGH){
      stateLED = LOW;
       stateLED = HIGH;
    time = millis();
  digitalWrite(LED, stateLED);
  previous == stateButton;
i don`t get this line of code and what &amp implementation in this code
i have some knowledge with c
I guess that you copied this code from a Web page and it included HTML characters such as & as a substitute for &
The code should probably be
UKHeliBob:
the place i copied this from is using a code format so i dont think HTML got to it
but i will try that edit
but can you explain please
what this -time debounce about ?
Thanks for help !
Ma-Mi:
what this
-time debounce
about ?
I guess you mean the element from the if statement that should probably be
That makes perfect sense.
Steve
Ma-Mi:
Dude, HTML most certainly got into it.
Ma-Mi:
Any mechanical switch has "bounce" - it doen't just go on and off. When you operate the switch, it will go on-off a couple of times because of its mechanical elasticity. To deal with this, when a switch changes state sketches will usually ignore any further changes on the switch for a short interval of time - a few milliseconds or so.
