Little Mini Camera and solar charging?
Hey Everyone!!
So I was wondering if I could make a little mini wide angle camera that could record images on a TF card or other type of memory. I would like to use a little solar panel to charge the battery to make the unit run. Is this is simple little project?? I want to put these in bird houses.
Thoughts and advice would be great!!!!!
Thanks all!
Dezi
That totally depends of your skill set.
It seems like there's off the shelf solutions already that are probably easier and cheaper. Is there another reason you want to do it this way specifically?
Not Really Trying to find the simplest solution. And for a decent price. I can solder, and I'm good with my hands if that helps..I don't mind making things but if you think it is a better benefit for me to purchase off the shelf products, then so be it :slight_smile:
You asked if it would be a simple project which is highly subjective. We don't know what you think is simple so it's far safer in my opinion to recommend something off the shelf. If you're also looking to learn then set your mind to it no matter what. :wink:
Maybe an ESP32CAM ?
Screenshot - 23_03_2023 , 19_16_52
