Little problem with sending AT command to Quectel UG95
Hello,
I have a problem with my code but I do not know, I communicate with the module 3G click quectel UG95 and my module Arduino UNO to send AT commands, but I do not receive anything, While with my module FTDI (Usb - uart) I have a reply from my module quactel UG95, I made a small program on arduino and I tested it with my module FTDI (usb - uart) and it works normally. I can not get that is my problem you can help me. thank you very much.
int octetIn=0;
char charIn = 0;
int compt = 0;
String chaineIn="";
boolean chaineComplete = false;
pinMode(12, OUTPUT);
Serial.println(“Starting…\n”);
delay(800); // wait for a second
digitalWrite(12, LOW); // turn the LED off by making the voltage LOW
digitalWrite(12, HIGH); // turn the LED on (HIGH is the voltage level)
delay(5000); // wait for a second
Serial.println(“Send AT\n”);
void writeString(String stringData) {
for (int i = 0; i < stringData.length(); i++)
Serial.write(stringData*);*
    void loop(){
  • Serial.print(“AT\r\n”);*
  • delay(1000);*
  • if (chaineComplete)*
  • Serial.println(“chaine recu :” + chaineIn);*
  • writeString(chaineIn);*
  • chaineIn = “”;*
  • compt = 0;*
  • chaineComplete = false;*
    void serialEvent(){
  • while(Serial.available()>0)*
  • charIn = (char) Serial.read();*
  • chaineIn += charIn;*
  • if(charIn == ‘\n’)*
  • chaineComplete = true;*
    [/quote]
