Hi
I am trying to use the Async WifiManager and the LittleFS in parallel to have separated files for .html, .css and .js.
The Async WifiManager starts and I can setup my network connection with a static IP.
But as soon as I upload new html, css and js files with the LittleFS file manager, the configuration is lost and I have to setup my network configuration again.
I would highly appreciate some hints how to solve that.
Thanks in advance,
Roger
Start by posting your code
************************************** WebServerTemplate.ino **************************************
Sketch
#include <LittleFS.h>
#include <RokWifi.h>
#include <ESPAsyncTCP.h>
#include <ESPAsyncWebServer.h>
AsyncWebServer server(80);
String processor(const String& var){
Serial.println("process variable " + var);
if(var == "TITLE"){
return "ESP - Template";
return String();
if (LittleFS.begin()) {
Serial.println("Filesystem mounted");
else {
Serial.println("ERROR!!! Filesystem not mounted...");
initRokWifi(&server);
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(LittleFS, "/index.html", String(), false, processor);
server.begin();
void loop() {}
Library for personal adoption of ESPAsyncWifiManager
************************************** RokWifi.h **************************************
#ifndef __ROKWIFI__
#define __ROKWIFI__
#include "Arduino.h"
#include <ESPAsyncWebServer.h> //Local WebServer used to serve the configuration portal
extern void initRokWifi(AsyncWebServer *importserver);
#endif
************************************** RokWifi.cpp **************************************
#include "RokWifi.h"
#include <LittleFS.h> //this needs to be first, or it all crashes and burns...
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <ESPAsyncWiFiManager.h>
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
char _static_ip[16] = "192.168.1.";
char _static_gw[16] = "192.168.1.1";
char _static_sn[16] = "255.255.255.0";
bool _shouldSaveConfig = false;
DNSServer dns;
void _saveConfigCallback () {
Serial.println("Should save config");
_shouldSaveConfig = true;
void initRokWifi(AsyncWebServer *server) {
if (LittleFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = LittleFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonDocument json(1024);
auto deserializeError = deserializeJson(json, buf.get());
serializeJson(json, Serial);
if ( ! deserializeError ) {
if (json["ip"]) {
Serial.println("setting custom ip from config");
strcpy(_static_ip, json["ip"]);
strcpy(_static_gw, json["gateway"]);
strcpy(_static_sn, json["subnet"]);
Serial.println(_static_ip);
Serial.println("no custom ip in config");
Serial.println("failed to load json config");
AsyncWiFiManager wifiManager(server, &dns);
wifiManager.setSaveConfigCallback(_saveConfigCallback);
//set static ip
IPAddress _ip, _gw, _sn;
_ip.fromString(_static_ip);
_gw.fromString(_static_gw);
_sn.fromString(_static_sn);
wifiManager.setSTAStaticIPConfig(_ip, _gw, _sn);
wifiManager.setMinimumSignalQuality();
if (!wifiManager.autoConnect("ESPWifiSetup", "")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
//save the custom parameters to FS
if (_shouldSaveConfig) {
Serial.println("saving config");
json["ip"] = WiFi.localIP().toString();
json["gateway"] = WiFi.gatewayIP().toString();
json["subnet"] = WiFi.subnetMask().toString();
File configFile = LittleFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
serializeJson(json, configFile);
configFile.close();
Serial.println("local ip");
Serial.println(WiFi.gatewayIP());
Serial.println(WiFi.subnetMask());
