LittleFS on SD Card
I just started my first experiments with Arduino and got a LittleFS filesystem working while using the internal flash of my micro controller. Now, I would like to attach some storage in form of a SD card.
Is it possible to use the LittleFS filesystem in conjunction with a SD card? The SD/SDFS libraries only seem to support FAT filesystems but not LittleFS.
Hi, welcome to the forum.
For which Arduino board is it ?
Why do you want the LittleFS on a SD card ? When using FAT16/32, then a computer can read and write files.
As far as I know, the LittleFS is always used internally. Sorry, but I don't know a Arduino LittleFS for a SD card. Suppose you can find such a library or make it yourself, then how would you know that it is reliable ?
For my initial experiments I'm using a TinyS2 (ESP32-S2).
I prefer LittleFS over FAT because it can deal with power loss which the latter cannot reliably. Luckily for Linux and BSD there exists a FUSE driver so I can read those LittleFS formatted SD cards on my computer, too.
More links please.
TinyS2 : https://unexpectedmaker.com/tinys2 and also sold by Adafruit.
You are not looking for a Arduino library, but for a ESP32 library.
Meanwhile, I read about the FUSE LittleFS driver, so it would be a obvious choice to make LittleFS for a SD memory card.
However, when I try to find that, I go down a rabbit hole and get confused. I assume you have already searched everywhere. I'm afraid that I can't help. Someday, someone has to make this.
Here is a note/request for it: https://github.com/lorol/LITTLEFS/issues/5#issuecomment-866239024
