Live update of thresholds on the mpr121
I have this breakout: SparkFun Capacitive Touch Sensor Breakout - MPR121 - SEN-09695 - SparkFun Electronics
Has anyone here successfully used a potentiometer to update the thresholds dynamically? I am trying to make the sensitivity adjustable with two potentiometers but I don’t seem to be able to update the threshold values at runtime. I think it is because the values are “read only” when the sensor is in “Run mode”.
I am however trying to set it to stop mode by calling set_register(0x5A, ELE_CFG, 0x00); before I try to update the values and then set_register(0x5A, ELE_CFG, 0x0C); after I update.
Does not work for me and I am sure I am misunderstanding something.
Anyone willing to share some experience regarding this scenario?
Do you have any code tried yet?
if so can you post it?
Here is my full code. Two things that may be causing the problem I think:
  • The mpr121 does not go into stop mode so the values are read only
  • I am sending decimal values ( not hex )
/*Copyright (c) 2010 bildr community
 Permission is hereby granted, free of charge, to any person obtaining a copy
 of this software and associated documentation files (the "Software"), to deal
 in the Software without restriction, including without limitation the rights
 to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 copies of the Software, and to permit persons to whom the Software is
 furnished to do so, subject to the following conditions:
 The above copyright notice and this permission notice shall be included in
 all copies or substantial portions of the Software.
 THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 THE SOFTWARE.
#include <Wire.h>
#include <MedianFilter.h>
// MPR121 Register Defines
#define MHD_R	0x2B
#define NHD_R	0x2C
#define	NCL_R 	0x2D
#define	FDL_R	0x2E
#define	MHD_F	0x2F
#define	NHD_F	0x30
#define	NCL_F	0x31
#define	FDL_F	0x32
#define	ELE0_T	0x41
#define	ELE0_R	0x42
#define	ELE1_T	0x43
#define	ELE1_R	0x44
#define	ELE2_T	0x45
#define	ELE2_R	0x46
#define	ELE3_T	0x47
#define	ELE3_R	0x48
#define	ELE4_T	0x49
#define	ELE4_R	0x4A
#define	ELE5_T	0x4B
#define	ELE5_R	0x4C
#define	ELE6_T	0x4D
#define	ELE6_R	0x4E
#define	ELE7_T	0x4F
#define	ELE7_R	0x50
#define	ELE8_T	0x51
#define	ELE8_R	0x52
#define	ELE9_T	0x53
#define	ELE9_R	0x54
#define	ELE10_T	0x55
#define	ELE10_R	0x56
#define	ELE11_T	0x57
#define	ELE11_R	0x58
#define	FIL_CFG	0x5D
#define	ELE_CFG	0x5E
#define GPIO_CTRL0	0x73
#define	GPIO_CTRL1	0x74
#define GPIO_DATA	0x75
#define	GPIO_DIR	0x76
#define	GPIO_EN		0x77
#define	GPIO_SET	0x78
#define	GPIO_CLEAR	0x79
#define	GPIO_TOGGLE	0x7A
#define	ATO_CFG0	0x7B
#define	ATO_CFGU	0x7D
#define	ATO_CFGL	0x7E
#define	ATO_CFGT	0x7F
// Global Constants
#define TOU_THRESH	0x06
#define	REL_THRESH	0x0A
// Using this instead of the constants
int touchThreshold = 6;
int releaseThreshold = 10;
MedianFilter filter_0;
MedianFilter filter_1;
int analogA0;
int filteredA0;
int lastFilteredA0;
int analogA1;
int filteredA1;
int lastFilteredA1;
int irqpin = 2;  // Digital 2
boolean touchStates[12]; //to keep track of the previous touch states
  pinMode(irqpin, INPUT);
  digitalWrite(irqpin, HIGH); //enable pullup resistor
  Wire.begin();
  filter_0.begin();
  filter_1.begin();
  mpr121_setup();
  readTouchInputs();
void readTouchInputs() {
  analogA0 = analogRead(A0) / 4;
  analogA1 = analogRead(A1) / 4;
  filteredA0 = filter_0.run(analogA0);
  filteredA1 = filter_1.run(analogA1);
  if (filteredA0 != lastFilteredA0 || filteredA1 != lastFilteredA1)
    lastFilteredA0 = filteredA0;
    lastFilteredA1 = filteredA1;
    //Serial.print(filteredA0);
    //Serial.print(" - ");
    //Serial.println(filteredA1);
    // If the potentiometers changed then I redo the setup
    // Pretty brutal I guess but it should work
    mpr121_setup();
  if (!checkInterrupt()) {
    //read the touch state from the MPR121
    Wire.requestFrom(0x5A, 2);
    byte LSB = Wire.read();
    byte MSB = Wire.read();
    uint16_t touched = ((MSB << 8) | LSB); //16bits that make up the touch states
    for (int i = 0; i < 12; i++) { // Check what electrodes were pressed
      if (touched & (1 << i)) {
        if (touchStates[i] == 0) {
          //pin i was just touched
          Serial.print("pin ");
          Serial.print(i);
          Serial.println(" was just touched");
        } else if (touchStates[i] == 1) {
          //pin i is still being touched
        touchStates[i] = 1;
          Serial.print(i);
          Serial.println(" is no longer being touched");
          //pin i is no longer being touched
        touchStates[i] = 0;
void mpr121_setup(void) {
  // Section A - Controls filtering when data is > baseline.
  set_register(0x5A, MHD_R, 0x01);
  set_register(0x5A, NHD_R, 0x01);
  set_register(0x5A, NCL_R, 0x00);
  set_register(0x5A, FDL_R, 0x00);
  // Section B - Controls filtering when data is < baseline.
  set_register(0x5A, MHD_F, 0x01);
  set_register(0x5A, NHD_F, 0x01);
  set_register(0x5A, NCL_F, 0xFF);
  set_register(0x5A, FDL_F, 0x02);
  // Section C - Sets touch and release thresholds for each electrode
  set_register(0x5A, ELE0_T, touchThreshold);
  set_register(0x5A, ELE0_R, releaseThreshold);
  set_register(0x5A, ELE1_T, touchThreshold);
  set_register(0x5A, ELE1_R, releaseThreshold);
  set_register(0x5A, ELE2_T, touchThreshold);
  set_register(0x5A, ELE2_R, releaseThreshold);
  set_register(0x5A, ELE3_T, touchThreshold);
  set_register(0x5A, ELE3_R, releaseThreshold);
  set_register(0x5A, ELE4_T, touchThreshold);
  set_register(0x5A, ELE4_R, releaseThreshold);
  set_register(0x5A, ELE5_T, touchThreshold);
  set_register(0x5A, ELE5_R, releaseThreshold);
  set_register(0x5A, ELE6_T, touchThreshold);
  set_register(0x5A, ELE6_R, releaseThreshold);
  set_register(0x5A, ELE7_T, touchThreshold);
  set_register(0x5A, ELE7_R, releaseThreshold);
  set_register(0x5A, ELE8_T, touchThreshold);
  set_register(0x5A, ELE8_R, releaseThreshold);
  set_register(0x5A, ELE9_T, touchThreshold);
  set_register(0x5A, ELE9_R, releaseThreshold);
  set_register(0x5A, ELE10_T, touchThreshold);
  set_register(0x5A, ELE10_R, releaseThreshold);
  set_register(0x5A, ELE11_T, touchThreshold);
  set_register(0x5A, ELE11_R, releaseThreshold);
  // Section D
  // Set the Filter Configuration
  // Set ESI2
  set_register(0x5A, FIL_CFG, 0x04);
  // Section E
  // Electrode Configuration
  // Set ELE_CFG to 0x00 to return to standby mode
  set_register(0x5A, ELE_CFG, 0x0C);  // Enables all 12 Electrodes
  // Section F
  // Enable Auto Config and auto Reconfig
  /*set_register(0x5A, ATO_CFG0, 0x0B);
  set_register(0x5A, ATO_CFGU, 0xC9);  // USL = (Vdd-0.7)/vdd*256 = 0xC9 @3.3V   set_register(0x5A, ATO_CFGL, 0x82);  // LSL = 0.65*USL = 0x82 @3.3V
  set_register(0x5A, ATO_CFGT, 0xB5);*/  // Target = 0.9*USL = 0xB5 @3.3V
boolean checkInterrupt(void)
  return digitalRead(irqpin);
void set_register(int address, unsigned char r, unsigned char v)
  Wire.beginTransmission(address);
  Wire.write(r);
  Wire.write(v);
  Wire.endTransmission();
Wire.endTransmission() returns an code 0 == OK, else is error. You might want to check that
change this
  Wire.write(r);
  Wire.write(v);
  int x = Wire.endTransmission();
  if (x != 0)
    Serial.print("\n Wire error :");
    Serial.print(x);
Thanks.
Looks like the write methods returns no error so the write should be working - but it doesn't seem to unfortunately. Any other ideas?
Best,
Sammi
Oops!
How stupid of me. I had forgotten to actually update the touchThreshold & releaseThreshold variables before calling setup again.
Works perfect now.
Thank you for your help.
Sammi
