LM1881 and Arduino Nano
My goal is to overlay data from NRF24L01+ to my TV's PAL/NTSC signal.
How would one wire LM1881 chip to an Arduino Nano so that output from the Nano would be overlaid to the TV box's signal?
That chip is a sync separator.
It extracts sync pulses from an EXISTING video signal.
Leo..
There are two existing signals. I am asking this because this is the chip Video Experimenter Shield uses to create a overlay but I do not know how this should be wired up when separated.
An overlay is something you put on top of an existing video signal.
Give us more info/links.
Leo..
Avamander:
...output from the Nano would be overlaid to the TV box's...
Video Experimenter Shield is for Uno. I have a Nano and I wish to overlay data to my TV box's signal that means I wish to replicate some of that shield's functions. They use LM1881 to overlay and I want to use the same chip but without those extra features the shield offers. Am I clear enough now?
Yes, all clear now.
The eagle files (schematic) are on that website.
Should be easy to replicate on a piece of veroboard.
The chip does NOT create or add the overlay.
It's a sync pulse extracter. A timing IC.
It tells the Arduino WHEN to insert text.
The Arduino inserts the actual text with resistors and diodes (D1, R2).
Leo..
Wawa:
Yes, all clear now.
Leo..
I knew that. I did try to modify the schematics to exclude unnecessary components but there were a few I had no idea of what they do. (See the area around switces and pots in the eagle files) I just wanted a really simple schematic with only overlay (timing) function but I was unable to create one.
You just have to work out what switch positions and jumpers you need, by reading the instructions.
And then see what you can/can't remove.
I think the switch is drawn in the "overlay" position.
Do you have video "through" (in to out).
Leo..
Wawa:
Leo..
Is this all okay? Will this work?
You can offload all the heavy processing from the arduino and use this chip - it's specially made for the purpose of OSD.
// Per.
Zapro:
// Per.
It's SMD, requires SPI (already occupied by radio) and a "bit" pricey for a beginner.
(Altho if someone would tell me how would I be able to use NRF24L01+ alongside with this I'd even look into using this)
Avamander:
It can be done quite cheap, and you get an extra micro (co-processor for OSD, etc) eBay
It seems very tempting but bit pricey. If someone could verify the validity of the schematics I posted that would be great.
Reset button is not needed, unless your shield is going to cover Arduino's reset button.
Pin3 of the LM1881 does not connect to pin 2 of the LM1881, but to shield D2.
I think Diode D2 has to be a wire. D2 is not used in "overlay".
Better try this first on a breadboard.
Leo..
Wawa:
Leo..
Is it right now?
I will most certainly try this first on a breadboard.
Looks ok now, except for the missing pot on A2.
I don't know if it's needed.
I assume you have read the whole article.
Leo..
Wawa:
Leo..
Many thanks, I now know exactly what to buy.
