Hello, I am working on a portable retro game console and am trying to get the battery circuit working. I am powering the circuit with a 3.7v 4500mAh lipo battery, so I wanted to use a boost converter to boost the voltage up to 5v so I could power all of my components. Here is the converter I purchased: https://www.amazon.com/dp/B06XRN7NFQ/ref=cm_sw_r_cp_api_glt_fabc_TJTXY59JSCW61ASRQJYB
It had good reviews and it said it could boost voltage up to 35v which was more than enough for my project. Unfortunately, when I got it and plugged in my battery, adjusting the potentiometer did not have an effect. After multiple counter clockwise turns I was able to get the voltage down to 1.2v, but once I boosted up to around 3.3v it would take a lot of clockwise rotations to even boost it up to 3.5v, and I couldn’t get it to go any higher. Is there something I’m doing wrong? Is my bird faulty? Should I purchase a different board?
The output voltage is strictly less than the input voltage for a buck converter like the LM2596. Give it 40V on the input and you'll easily be able to see 35V on the output...
Where did you see anything about the LM2596 boosting? Its a buck converter chip.
The link you provide clearly states "step down" and "buck".
