I’ve been struggling to get LM2917 work but, no luck (all i am getting is 0v at pin-5). There’s not enough documentation for 14pin version of chip. I have attached the circuit diagram. Could anyone please take a look and see if i am doing something wrong?
I have generated a 1Khz square wave using arduino due and haven’t used any coupling circuit at the input pin of lm2917 (connected directly). Also arduino due outputs 3.3v means, lm2917 is getting 3.3v square wave at pin-1 (i think input signal range of lm2917 is 0-28V , so this should not be a problem).
First things first.
1-Where did you get the schematic you posted ?
2- Did you read the datasheet ? (see attached)
3- How can you explain the fact that you have no resistance from pin -5 to ground (see Figure 23 & 24 on page 11.
you are right! but this is my first time working with 3.3v micro controller board and i probably forgot about it. (thats why i am using lm2907 for this purpose, also it takes the load off of the micro controller)
I am testing LM2917 as shown in the attached diagram with a 5V square wave generated by the signal generator and it is working fine. As I change the frequency it responds quickly.
crazy thing- just for curiosity sake i inserted op-amp buffer in between the signal generator and the lm2917 input, guess what…didn’t work. i don’t know whats wrong here.
Thanks for reply. i will try. but so that you know hall sensor that i am using can provide unto 20mA of source current that should be enough to drive the lm2917.
Are we talking about the same thing ? I'm talking about the resistor in your schematic across the hall effect sensor that has no value shown . Is that 10k ? (please tell me it's not).
