I am quite new to using Arduino, my project is to build a LM335 temperature sensor circuit that will record the temperature in Celsius then have the ability to recall temperatures for the last 24 hours with a reading every 30 mins. My main problem is I have no idea how to store these readings as I have tried arrays but my understanding of how to input new values is zero. I am using a LCD to place the readings on. I would like to have the memory to be saved after turn off so EEprom is the best choice for saving it.
Any ideas. Thank you
I have attached my code so far below.
Temp_2.ino (1.26 KB)
Welcome to the forum, it would be easier to read your sketch if you posted it between code tags.
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Thanks. Tom…
No reason why you cannot store and readback your 48 readings sequentially in internal eeprom.
Just look in the Arduino Reference pages and the ide Examples.
You might find coding a routines for displaying the daily min /max and average temperatures handy.
If you are wanting to store many days readings then you may have to look at additional external eeprom or a sd card , which are often part of a glcd/tft screen module.
