I have a arduino micro connected with the outputs of the LM339 (open collector opamp). But i have no place for the pull-ups for the outputs of LM339 on my PCB. I have read that there are some internal pull-ups, but shall this work with the arduino and the LM339?
For the record.. An LM339 is NOT an Op-Amp.. It's a comparator..
The pin compatible Op-Amp is an LM324.
Note that the output swing is limited to -1.25V from the plus supply rail and +1.25 V from ground for a max of +/- 2.5V, assuming a 5V supply rail...
An LMC660 will swing to ~. .3 - .4V of either rail and is also pin compatible.
