LM35 help pls ???
I’m planning to use only one temperature sensor for two different arduinos (same uno rev3), will the data transmission from the sensor towards the arduinos be slown down/diminished if i connect them this way ?
one more thing, if i’m to remove the breadboard , what connecting piece/board can i use (such as terminal blocks) to do this connection?
if possible , i really needed to use only one sensor for the two arduinos
think it is a recipe for problems.
use one Arduino to read the sensor and sent the value (opt. on request) to the other Arduino.
Schematic is OK. Both Arduinos must share common GND (add one wire)
