LM35 not activating switch on 5v Relay
Pulling my hair out a little bit on this, but I have a 5v relay switched by an LM35 voltage sensor, and it gives somewhat sketchy temp readings, but not too far off, but will only light the Relay on LED a bit, and not switch the switch on.
This is set to turn on an AC powered fan plugged into an outlet wired to the relay.
This seems super simple, and a simple on-off program runs the relay and fan perfectly.
The addition of the LM35 and appropriate code, just lights the LED a bit, not fully, it appears as if voltage is dropping.
Any assistance would be appreciated. I’m stumped, other than a few threads mentioning powering the relay itself, which this particular model, I’m not sure how that would be done.
Running this code:
//the output pin of the lm35 sensor
int lm35Pin = A1;
  // set up serial at 9600 baud
  int analogValue;
  float temperature;
  // read our temp sensor
  analogValue = analogRead(lm35Pin);
  // convert the 10bit analog value to celcius
  temperature = float(analogValue) / 1023;
  temperature = temperature * 500;
  // print the temp over serial
  Serial.print("Temp: ");
  Serial.print(temperature);
  Serial.println("C");
  Serial.print(analogValue);
  if(temperature > 31)
  digitalWrite(9,HIGH);
  else if(temperature < 31)
  digitalWrite(9,LOW);
  // wait 1s before reading the temperature again
  delay(2000);
It might help if you set the relay pin to OUTPUT in setup().
pinMode(9, OUTPUT);
Leo..
I assume you use an Uno.
Using the internal 1.1volt Aref could make temp readout more stable.
Try this modified (untested) sketch.
Leo..
float tempC;
  analogReference(INTERNAL); // use internal 1.1volt Aref
  pinMode(9, OUTPUT);
  tempC = analogRead(A0) * 0.1039; // calibrate by changing 0.1039
  if (tempC > 31) digitalWrite(9, HIGH);
  else digitalWrite(9, LOW);
  Serial.print(tempC, 1); // one decimal place
  delay(2000);
Wawa:
I would like to write the above code as follows:
tempC = (float)100*(1.1/1024)*analogRead(A0);// tempC = (float)0.1074*analogRead(A0);
OR
tempC = (float)100*(1.1/1023)*analogRead(A0);// tempC = (float)0.1075*analogRead(A0);
Wouldd appreciate to know the source of the figure 0.1039?
GolamMostafa:
Exactly what you did, but compressed to a single number.
And calculated with the Aref voltage of my Arduino.
Every Arduino has a slightly different (but stable) 1.1volt Aref, that can be between 1.0 and 1.2 volt.
Mine was about 1.064volt.
Leo..
You can measure it with a voltmeter between Aref and Gnd when internal reference is activated.
Wawa:
Leo..
So, tempC comes as:
= 100*(1.064/1024)*analogRead(A0);
//1.064 is the actual measured value at AREF-pin for the INTERNAL option of analogReference(arg)
= 0.1039*analogRead(A0);
Excellent!
To Leo,
Big miss in not setting that to output. It was what was wrong as I'm sure you knew.
Thanks, and I was already implementing the aref code you posted from another similar question. Thanks for that as well. I've been out of Arduino for a bit and needed to get this put together quickly as we have 6 week old Ducks that need some air flow in their coop during our, now record setting, heat wave. (109 in Austin today.)
Shawn
Could add some hysteresis there, to stop the fan from turning on/off too fast.
if (tempC < 28) digitalWrite(9, LOW);
Wish I was there for a few days.
Winter, rain, the flu, and ~8C (46F) here.
Leo…
