I am facing difficulty like i am getting two fluctuating values with this type of code which may be can be kept constant by taking average or something but i am not sure whether the temperature it is showing is correct or not because i tried a different code suggested by someone else that is giving a different value...you can see my post below in the sensor section on LM35 not much older....
vishal_3:
the sensors that we have it is Fake that is the problem!! i just try one sensor that is have from my charger and it is work With both codes correctly! i open and i read the Small letters on the sensor that he is works it is writes (653J5 LM35 DZ) the sensor Who does not work writes (62AB LM35 DZ) Whoever reads the thread do not buy 62AB LM35 DZ it not working!
xenofon:
Get the temperature of your place by some other way(credible source) and then compare that with the reading of your new LM35 and old LM35 with this code then the authenticity will be tested.....
vishal_3:
