Arduino Uno, HLK-RM04 Wifi module and LM35 temperature sensor.
I'm using the below sketch on the Arduino, and when powered with USB cable from PC the temp. readings are correct.
But, when I power all components with a 12v 7Ah battery through a 7805 5V DC regulator, the temp. readings from the LM35 drop approx. 20 degrees F??
I tested the 5v pins on the Arduino that feed the LM35 and they are getting the same 4.78v regardless of USB cable or 12v battery.
I know this battery has not been charged for awhile, would that make a difference?
The battery terminals test out at 12v.
thanks.
//Arduino sketch created by Nikos Georgousis
//Dec 2014
//Based on http://rayshobby.net/?p=9592 example
//Wireless temperature sensor with LM-35 and HlK-RM04
float analogVal;
float temp;
float referenceVoltage;
Serial.begin(57600);
analogReference(INTERNAL);
referenceVoltage = 2.00; //Set to 5, 3.3, 2.56 or 1.1 depending on analogReference Setting
boolean has_request = false;
if (Serial.available()) {
while(Serial.available()) {
char c = Serial.read();
has_request = true;
if (has_request) {
Serial.println("HTTP/1.1 200 OK");
Serial.println("Content-Type: text/html");
Serial.println("Connection: close"); // the connection will be closed after completion of the response
Serial.println("Refresh: 5"); // refresh the page automatically every 5 sec
String sr = "<!DOCTYPE HTML>\n";
sr += "<html>\n";
analogVal=0;
temp=0;
int analogChannel = 1; // Sensor should be connected to Analog 1
for(int i = 0; i < 30; i++) { // Get 30 readings from teh sensor to have an acurate result
analogVal += (analogRead(analogChannel)* 0.48828125);
delay(5); //Delay each reading for 5 millisecons
temp=analogVal/30; //Get the average value
temp = (referenceVoltage * temp * 100) / 1023; // Caclulate Celsius value correctly
sr += "<center>";
sr += "<h1 style=color:blue>";
sr +=temp;
sr+="</h1>";
sr += "
\n";
sr += "Created by Nikos Georgousis\n";
sr += "</center>";
sr += "</html>";
Serial.print("Content-Length: ");
Serial.print(sr.length());
Serial.print("\r\n\r\n");
Serial.print(sr);
