LM358 module - how to connect?
can anybody help me connect a condenser mic to a LM358 module to the Arduino.
I have a LM358 module like the one at http://www.wayengineer.com/index.php?main_page=product_info&products_id=2981
I have the VCC and GND connected and the power led comes on but no matter how I connect the IN and OUT connectors I do not get a proper signal to the Arduino.
At the moment: I have the mic connected to IN and GND (GND on the mic to GND) (I have tried the other way as well). I have the OUT connected to pin A2 on the Arduino
I get a reading of around 500 (the value fluctuates between about 490 and 520). Changing the onboard pot does not effect the value. EDIT - just found out I get the same reading when the mic is not connected.
I have contacted the company I purchased it from and they don't know. Even though they sell it as Arduino compatible.
Provide a schematic of what you’ve done.
Doing this stuff verbally, and with all that back-and-forth, is a waste of time.
Draw a picture of your circuit, take a decent picture of that and upload it as an attachment.
A condenser (electret) mic requires power.
It’s not like a crystal mic.
In my dwg, attached, there are some biasing resistors and coupling caps.
“+V” should not be greater than 3V.
If you don’t like it, google for others.
That's sort-of a good thing... With no signal the Arduino ADC should by biased at 2.5V (half of the full-scale 1023 reading with the default 5V reference). ...I didn't see anything in the amplifier modual discription saying that.
Now, you just have to get a signal from your mic to the amp, and the readings shoul jump-around, centered around approximately 512.
Get a "dynamic microphone". The condensor mic needs up to 48 volts to provide static electricity. Or maybe 5 volts... Read this...
http://en.wikipedia.org/wiki/Phantom_power
here’s the circuit:
Here’s the sketch I am using to test:
int micPin = 1;
int micVal = 0;
int oldMicVal = 0;
int micMax = -9;
int micMin = 9999;
int ledPin = 13;
  while (!Serial)   {  ; // wait for serial port to connect. Needed for Leonardo only
  pinMode(ledPin, OUTPUT);
  micVal =  analogRead(micPin);
  if (micVal >560)            {  digitalWrite(ledPin, HIGH);  delay(100);   digitalWrite(ledPin, LOW);    }
  if (micVal > micMax )     {  micMax = micVal;  }
  if (micVal < micMin )      {  micMin = micVal;   }
  Serial.print("\nmicVal = ");Serial.println(micVal);
  Serial.print("micMax = ");Serial.println(micMax);
  Serial.print("micMin = ");Serial.println(micMin);
  delay(10);
and here is the output I am getting:
micVal = 515
micMax = 529
micMin = 502
micVal = 514
micMax = 529
micMin = 502
micVal = 527
micMax = 529
micMin = 502
micVal = 511
micMax = 529
micMin = 502
micVal = 513
micMax = 529
micMin = 502
micVal = 513
micMax = 529
micMin = 502
micVal = 508
micMax = 529
micMin = 502
I get the same values when I remove the mic.
AmbiLobe: Get a "dynamic microphone". The condensor mic needs up to 48 volts to provide static electricity. Or maybe 5 volts... Read this...
WTF!
http://www.epanorama.net/circuits/microphone_powering.html
Don't post if you don't know anything!
