LM358 saturates the output
Can you change the values I have highlighted, and recalculate the 75K to give the gain you need with 4K7 or 10K input resistors.
Place a 1uF cap from the junction of the two 10K providing the 1/2 Vcc, to gnd.
10uF is too high for the high values of resistors you are using.
Tom... :slight_smile:
Wawa:
Can be explained if there is someting wrong with the input caps on the pots.
If there is a DC short/leak to ground there, then the opamp tries to compensate by increasing it’s output.
Did you connect the 10uF caps with negative to pot and positive to 50k resistor.
Post a picture of the setup.
Leo…
Hi Leo,
You were right the input capacitors were assembled the wrong way. Now the Output DC voltage follows the one of +Vi :slight_smile: Thanks…
I changed the voltage divider to 2x100k and the output signal is centered at Vcc/2. and I can get a max peak to peak voltage that depends on VCC as follows:
VCC MaxVPP
5 3
16 6
So while at 5V the output can swing up to 1.5v close to each rail, at 16V it can only swing up to 5V close to each rail. Any idea why there is a bigger gap as I use higher Vccs, and why most of the voltage is not translated into higher output amplitude.
TomGeorge:
Hi Tom
At this point I have a BW of 1-20KHz which is kind of important. Will this not change if I change the caps into 1UF?
Also If I change the 50K into 10K each will it not adversely affect the channel separation?
Thanks
No, the virtual ground at the opamp input takes care of that.
However as the pots are 50k you certain do not want to load them with 10k or 4k7, ideally they would not be loaded at all. With 10k you'd severely distort the linearity (or logarithmic response if the pot is log law). It would actually be better to use 100k for that reason, although high impedances have issues with pickup and noise. The existing 50k seems like a not unreasonable compromise.
A better approach overall is to buffer pot wiper voltage with a unity gain buffer, then the summing junction resistors can be a nice low (ie low noise) 1k or whatever. For a low noise microphone preamp you'd have to pay close attention to such issues, but that's not the case here of course.
Good pickup by TG.
OP.... make sure to always include polarity symbols for polarised capacitors in circuit diagrams.
The Vac drawing (from the original diagram) isn't really AC is such..... but is a combination of dc and ac.
Also..... make sure to write the voltage levels in waveform diagrams for making things clear. DC level.... clipping level etc
Hi, Example maximum channel separation. |500x335 From link I posted. Have you measured the BW?
Tom..... :)
MarkT: It would actually be better to use 100k for that reason, although high impedances have issues with pickup and noise. The existing 50k seems like a not unreasonable compromise.
Thanks for this recap.
In fact there are 3 inputs and one of those inputs is actually coming from a mic x10 preamp (transistor based). So I don't think it should not make a difference.
TomGeorge: Have you measured the BW?
Tom..... :)
Hi Tom,
Measured the BW ad it goes 1-25Khz
Thanks all, with all the help and comments I have this circuit (see attached). It works fine but there is two points that I do not understand.
  1. At 5V VCC it has a nice clean 3vpp output (centered at VCC/2) before it gets into saturation. However if I raise VCC to 15V it can only output 5Vpp before it gets into saturation. Why the higher VCC increase the output voltage amplitude in a very small proportion?
  2. Once it get into saturation the output signal, is not immediately clipped, but changes form sine wave into triangle ??
Anyone with an idea why this happens?
Thanks
