LM35DT/NOPB vs LM35DZ about 1 Celsius degree diference?
I have on same board two LM35 sensors, one is LM35DT the other LM35DZ.
The trouble is, they are one next to the other but still read different. And I mean about 1 degree difference.
Output of the serial:
Initializing...
Ready
LM35DT: 19.04
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.09
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
LM35DT: 18.55
LM35DZ: 17.58
They are like 0.5cm apart, both with isolated pins, LM35DT conencted to A0 and the other to A1, 1 second delay between each sensor measurement.
If you read the datasheet they state differences in accuracy between A/C/D models; but they both are D model, just different packaging.
Wondeing if I buy the LM35AH model, would give a 3rd different value? Are they really that diferent in performances as they are in prices?
Thanks.
They're analog, so vulnerable to variations in the components in their two circuits and the datasheet says they're accurate to 0.5 degrees. Thus, not an especially surprising result.
Can you post the code?
  • what is the timing between the reads?
  • does it also occur when you change the order?
  • or the pins used?
  • is your power supply stable?
1 seconds between each read
it's same if I change the order
it's same if I change the input pins
it's powered fro USB and I don't think the power fluctuate with such a steady rate to match every reading
Seems that the bigger TO-220 package is more 'cool' that the other :slight_smile:
