LM35DZ problem!!!!
Hi everyone
I connected Lm35dz to my Arduino Uno , and used this code:
float temp;
int tempPin = 0;
void setup(){
  pinMode(tempPin, INPUT);
void loop(){
temp = analogRead(tempPin);
temp = temp * 0.48828125;
Serial.print("TEMPRATURE = ");
Serial.print(temp);
Serial.print("*C");
BUT I received these outputs:
what is the problem ??
I have changed gnd and vcc pins but The result is same...
The output looks like there is no connection to your sensor. Provide a wiring diagram of your setup!
LM35 wiring
You have 5V connected to the sensor's GND and GND to the sensor's Vs+. According to the datasheet that may have fried your sensor. You can try to swap the two wires, maybe you're lucky and the sensor survived.
Thank you ...
