hi
i have arduion with waterproof sensor but every time i get different values
its give different data up to 10 digress changes every time
is the sensor bad ... or i missing something .. ?
- i tried with and without risistor 4.7 k same problem ..
hi
Please read and follow the directions in the "How to use this forum" post.
If you show us how you have it powered and connected to the Arduino and what code you're using to read it we might be able to help. Until then...
Steve
i treid this 3 combintaions :
1 and 2 gives me the same unstable results
3 gives me the same ubstable result plus 4k
the code :
vout=analogRead(sensor);
vout=(vout*500)/1023;
tempc=vout; // Storing value in Degree Celsius
Serial.print("water_temp=");
Serial.print(tempc);
delay(1000); //Delay of 1 second for ease of viewing
You ask a question about an analogue LM35 sensor, but you post pictures of a digital DS18B20 sensor.
Two completely different sensors.
So what do you have.
Leo..
this what i have :
Waterproof Digital Thermal Probe LM35DZ Temperature Probe sensor for Arduino
boze:
this what i have :Waterproof Digital Thermal Probe LM35DZ Temperature Probe sensor for Arduino
As said, the pictures show a DS18B20.
Post a link to where you have bought it.
Leo..
Simple sketch for a DS18B20.
Picture 3 (post#3) is correct.
Leo..
#include <DallasTemperature.h>
#include <OneWire.h>
OneWire oneWire(6); // pin D6
DallasTemperature sensors(&oneWire);
float temp;
Serial.println("DS18B20 thermometer");
sensors.begin();
sensors.requestTemperatures();
temp = sensors.getTempCByIndex(0);
Serial.print("Temp is ");
Serial.print(temp, 4);
Serial.println(" C");
i dont anderstend the logic of it ..
if i connect the wires without the resistor , i receive for example 30 degrees , but with the resistor i get 430 degrees , its just adding 4k to the result .
but even so with or without the resistor i get a non stable results every second of test .
get from 25 degrees , after 3 sec 34 degrees , and back to 20 degrees and ....
Did you use the code from post#7.
And connect the sensor to pin D6.
Post a picture of your setup.
Leo..
How long is the wire? Is it screened? Have you tried adding a 100nF to ground on the analog pin
to reduce EMI pic-up?
Wawa:
And connect the sensor to pin D6.Post a picture of your setup.
Leo..
i dont have DS18B20 so this code is not right...
i connected the wires like in pic 3
this is the link for the product i but
http://www.ebay.com/itm/Waterproof-Digital-Thermal-Probe-LM35DZ-Temperature-Probe-Sensor-1M-For-Arduino-/122609592516?hash=item1c8c19e8c4:g:PXkAAOSwdNFZcc6q
this is the code :
const int sensor=A1; // Assigning analog pin A1 to variable 'sensor'
float tempc; //variable to store temperature in degree Celsius
float tempf; //variable to store temperature in Fahreinheit
float vout; //temporary variable to hold sensor reading
pinMode(sensor,INPUT); // Configuring pin A1 as input
vout=(vout500)/1023;
tempf=(vout1.8)+32; // Converting to Fahrenheit
Serial.print("in DegreeC=");
Serial.print("\t");
Serial.print("in Fahrenheit=");
Serial.print("\t");
Serial.print(tempf);
You should have bought a waterproof DS18B20.
Much easier to use than the LM35.
Don't use a pull up resitor with the LM35.
Try this sketch. It uses the more stable 1,1vot Aref and averaging.
See the comments for temp calibration.
Leo..
// LM35 temp sensor connected to analogue input A1, +5volt and ground
unsigned int total; // A/D readings
float tempC; // Celcius
float tempF; // Fahrenheit
analogReference(INTERNAL); // use the internal ~1.1volt Aref | change to (INTERNAL1V1) for a Mega
total = 0; // reset total
for (int x = 0; x < 64; x++) { // 64(max) analogue readings for averaging
total += analogRead(A1); // add each value
tempC = total * 0.001632; // Calibrate by changing the last digit(s)
tempF = tempC * 1.8 + 32.0; // Celcius to Fahrenheit
Serial.print("The temperature is ");
Serial.print(tempC, 1); // one decimal place
Serial.print(" Celcius ");
Serial.print(tempF, 1); // one decimal place
Serial.println(" Fahrenheit");
delay(1000); // use a non-blocking delay when combined with other code
Wawa you'r code works great.
it fix the problem .
thanks a lot !!!!!
Reading this I have to say I think OP was cheated at least a bit by the advertisement, which advertises a digital sensor while in reality it's an analog one.
Also I must question the wisdom of buying from a vendor that uses a description that reads like a failed Google translation of Klingon or so. It's just about totally unintelligible what's written there! Do some research before ordering and save a lot of trouble later.
It seems someone stuffed an LM35DZ into a waterproof case that has been used for DS18B20 sensors before.
Leo..
