Heys guys:
I was making the Lo-Fi Arduino Guitar Pedal which is found on instructables.com (http://www.instructables.com/id/Lo-fi-Arduino-Guitar-Pedal/) , but when I wanted to upload the code (which is found on step # 6 ) the compiler throws this error(using the 0022 version of the Arduino IDE and an Arduino UNO):
GlitchPedal\dsp.cpp.o: In function `output(int, short)':
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/dsp.cpp:22: multiple definition of `output(int, short)'
dsp.cpp.o:C:\Users\Owner\AppData\Local\Temp\build2747389495505466526.tmp/dsp.cpp:22: first defined here
c:/users/owner/desktop/programas/utilities/arduino-0022/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
GlitchPedal\dsp.cpp.o: In function `setupIO()':
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/dsp.cpp:7: multiple definition of `setupIO()'
dsp.cpp.o:C:\Users\Owner\AppData\Local\Temp\build2747389495505466526.tmp/dsp.cpp:7: first defined here
GlitchPedal\timers.cpp.o: In function `getTimer':
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/timers.cpp:5: multiple definition of `getTimer(int)'
timers.cpp.o:C:\Users\Owner\AppData\Local\Temp\build2747389495505466526.tmp/timers.cpp:5: first defined here
GlitchPedal\timers.cpp.o: In function `getChannel(int)':
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/timers.cpp:13: multiple definition of `getChannel(int)'
timers.cpp.o:C:\Users\Owner\AppData\Local\Temp\build2747389495505466526.tmp/timers.cpp:13: first defined here
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/timers.cpp:5: multiple definition of `waveformGenerationMode(int, int)'
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/timers.cpp:5: multiple definition of `waveformGenerationMode(int, int, int)'
GlitchPedal\timers.cpp.o: In function `getPrescale01':
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/timers.cpp:60: multiple definition of `getPrescale01(int)'
timers.cpp.o:C:\Users\Owner\AppData\Local\Temp\build2747389495505466526.tmp/timers.cpp:60: first defined here
GlitchPedal\timers.cpp.o: In function `getPrescale2(int)':
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/timers.cpp:71: multiple definition of `getPrescale2(int)'
timers.cpp.o:C:\Users\Owner\AppData\Local\Temp\build2747389495505466526.tmp/timers.cpp:71: first defined here
GlitchPedal\timers.cpp.o: In function `timerPrescale(int, int)':
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/timers.cpp:45: multiple definition of `timerPrescale(int, int)'
timers.cpp.o:C:\Users\Owner\AppData\Local\Temp\build2747389495505466526.tmp/timers.cpp:45: first defined here
GlitchPedal\timers.cpp.o: In function `analogPrescale(int)':
C:\Users\Owner\Desktop\Programas\Utilities\arduino-0022\libraries\GlitchPedal/timers.cpp:86: multiple definition of `analogPrescale(int)'
timers.cpp.o:C:\Users\Owner\AppData\Local\Temp\build2747389495505466526.tmp/timers.cpp:86: first defined here
BTW I used the glitch pedal file
Thanks.
