Hello,
I have put together an D1 mini pro with HX711 and 4 load cells and when I run the code from HX711_ADC (Olav Kallhovd) the weight stabilize at 0 and I jump on the bed and the weight increases and drop when I exit it, it works for hours.
Then I used the code I found here GitHub - newAM/LoadCellOccupany: Home automation occupancy sensor using load cells and the weight start jump up and down many hundred kg so I thought it was something wrong with the weight code from newAM so I took out the WiFi and MQTT part and added it too HX711_ADC (Olav Kallhovd) code but the problem is the same...
This code the weight is stable and I can jump on the bed and get my weight, works for hours but doesn't output the weight to MQTT only on serial monitor.
HX711_ADC
Arduino library for HX711 24-Bit Analog-to-Digital Converter for Weight Scales
Olav Kallhovd sept2017
Settling time (number of samples) and data filtering can be adjusted in the config.h file
For calibration and storing the calibration value in eeprom, see example file "Calibration.ino"
The update() function checks for new data and starts the next conversion. In order to acheive maximum effective
sample rate, update() should be called at least as often as the HX711 sample rate; >10Hz@10SPS, >80Hz@80SPS.
If you have other time consuming code running (i.e. a graphical LCD), consider calling update() from an interrupt routine,
see example file "Read_1x_load_cell_interrupt_driven.ino".
This is an example sketch on how to use this library
#include <HX711_ADC.h>
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout = D0; //mcu > HX711 dout pin
const int HX711_sck = D2; //mcu > HX711 sck pin
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
Serial.begin(57600); delay(10);
Serial.println("Starting...");
LoadCell.begin();
//LoadCell.setReverseOutput(); //uncomment to turn a negative output value to positive
float calibrationValue; // calibration value (see example file "Calibration.ino")
calibrationValue = -7818.58; // uncomment this if you want to set the calibration value in the sketch
//EEPROM.begin(512); // uncomment this if you use ESP8266/ESP32 and want to fetch the calibration value from eeprom
#endif
//EEPROM.get(calVal_eepromAdress, calibrationValue); // uncomment this if you want to fetch the calibration value from eeprom
unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
LoadCell.start(stabilizingtime, _tare);
if (LoadCell.getTareTimeoutFlag()) {
LoadCell.setCalFactor(calibrationValue); // set calibration value (float)
Serial.println("Startup is complete");
else {
static boolean newDataReady = 0;
const int serialPrintInterval = 2000; //increase value to slow down serial print activity
// check for new data/start next conversion:
if (LoadCell.update()) newDataReady = true;
// get smoothed value from the dataset:
if (newDataReady) {
if (millis() > t + serialPrintInterval) {
float i = LoadCell.getData();
Serial.print("Load_cell output val: ");
Serial.println(i);
newDataReady = 0;
t = millis();
// receive command from serial terminal, send 't' to initiate tare operation:
if (Serial.available() > 0) {
char inByte = Serial.read();
if (inByte == 't') LoadCell.tareNoDelay();
// check if last tare operation is complete:
if (LoadCell.getTareStatus() == true) {
Serial.println("Tare complete");
Load_cell output val: -0.01
Load_cell output val: -0.03
Load_cell output val: -0.07
Load_cell output val: -0.08
Load_cell output val: -0.04
Load_cell output val: -0.11
Load_cell output val: -0.10
Load_cell output val: -0.09
Same code as over but added WiFi and MQTT, weight unstable and can't be used for anything.
HX711_ADC
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#if defined(ESP8266) || defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
// connection settings
#define TIMEOUT 5000 // connection failure timeout in ms
#define MQTT_PORT 1883 // MQTT broker port
#define MQTT_CLIENT_ID "loadcell" // device client ID
// Wifi settings
#define WIFI_CLIENT_ID "LOADCELL1"
#define SSID_NAME "IoT" // SSID network wifi name to connect to
#define SSID_PASSWORD "12345678" // Wifi password
// MQTT topics
#define TOPIC_BASE "loadcell/sensor/main-bedroom" // base topic
#define TOPIC_LOAD TOPIC_BASE "/load" // topic to publish samples on
#define TOPIC_TARE TOPIC_BASE "/tare" // topic to receive tare commands on
#define MQTT_USER "" // MQTT username
#define MQTT_PASS "" // MQTT password
#define MQTT_HOST IPAddress(192, 168, 1, 2) // MQTT broker ip
WiFiEventHandler gotIpEventHandler, disconnectedEventHandler;
WiFiClient scaleClient;
PubSubClient mqttClient(scaleClient);
// reconnects to the MQTT broker
void reconnect() {
// loop while disconnected
while (!mqttClient.connected() && WiFi.isConnected()) {
// attempt to connect
Serial.println("Attempting to establish connection to MQTT broker...");
if (mqttClient.connect(MQTT_CLIENT_ID, MQTT_USER, MQTT_PASS)) {
// print connection messaged for debug
Serial.println("Connection established to MQTT broker");
mqttClient.publish(TOPIC_BASE, "connected");
// subscribe to control topic
mqttClient.subscribe(TOPIC_TARE);
Serial.print("Failed to connect: ");
// print client state
switch (mqttClient.state()) {
case MQTT_CONNECTION_TIMEOUT:
Serial.println("MQTT_CONNECTION_TIMEOUT");
case MQTT_CONNECTION_LOST:
Serial.println("MQTT_CONNECTION_LOST");
case MQTT_CONNECT_FAILED:
Serial.println("MQTT_CONNECT_FAILED");
case MQTT_DISCONNECTED:
Serial.println("MQTT_DISCONNECTED");
case MQTT_CONNECTED:
Serial.println("MQTT_CONNECTED");
case MQTT_CONNECT_BAD_PROTOCOL:
Serial.println("MQTT_CONNECT_BAD_PROTOCOL");
case MQTT_CONNECT_BAD_CLIENT_ID:
Serial.println("MQTT_CONNECT_BAD_CLIENT_ID");
case MQTT_CONNECT_UNAVAILABLE:
Serial.println("MQTT_CONNECT_UNAVAILABLE");
case MQTT_CONNECT_BAD_CREDENTIALS:
Serial.println("MQTT_CONNECT_BAD_CREDENTIALS");
case MQTT_CONNECT_UNAUTHORIZED:
Serial.println("MQTT_CONNECT_UNAUTHORIZED");
default:
Serial.println("MQTT_STATE_UNKNOWN");
// delay before next attempt
delay(TIMEOUT);
// callback function for handling new messages on subscribed topics
void callback(char* topic, byte* payload, unsigned int length) {
// zero out scale offset
if (!strcmp(topic, TOPIC_TARE)) {
IPAddress mqttBroker(MQTT_HOST);
delay(10);
gotIpEventHandler = WiFi.onStationModeGotIP([](const WiFiEventStationModeGotIP& event) {
Serial.print("Station connected, IP: ");
disconnectedEventHandler = WiFi.onStationModeDisconnected([](const WiFiEventStationModeDisconnected& event) {
Serial.println("Station disconnected, will reconnect or still trying");
// connect with DHCP
WiFi.hostname(WIFI_CLIENT_ID);
Serial.printf("Connecting to %s ...\n", SSID_NAME);
WiFi.begin(SSID_NAME, SSID_PASSWORD);
// configure MQTT broker
mqttClient.setServer(mqttBroker, MQTT_PORT);
// set callback function
mqttClient.setCallback(callback);
LoadCell.begin();
#endif
if (newDataReady) {
float weight = LoadCell.getData();
Serial.println(weight);
mqttClient.publish(TOPIC_LOAD, String(weight).c_str(), true);
newDataReady = 0;
t = millis();
weight = 0;
// connect if disconnected
if (!mqttClient.connected()) {
if (WiFi.isConnected()) {
reconnect();
// maintain connection
mqttClient.loop();
Load_cell output val: -389.72
Load_cell output val: -209.98
Load_cell output val: 244.82
Load_cell output val: 249.28
Load_cell output val: -80.30
Load_cell output val: -382.72
Load_cell output val: -334.44
Load_cell output val: -221.93
Load_cell output val: -260.50
Load_cell output val: -146.83
Load_cell output val: -194.87
Load_cell output val: -264.98
Load_cell output val: -305.49
Load_cell output val: 14.79
Load_cell output val: 111.23
Load_cell output val: 238.00
Any help is appreciated
