Load cell error in if statements
Hello, Good Evening
I am beginner in arduino programming,
I am working in a project of loadcell, In this project I am using if statements,
I use arduino uno board, 20kg Loadcell, Hx711, 16*2 lcd display, leds & breadboad Jumperwires
My code is
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#include <HX711.h>
#define DT A0
#define SCK A1
#define sw 9
#define LED 13
long sample=0;
float val=0;
long count=0;
unsigned long readCount(void)
unsigned long Count;
unsigned char i;
pinMode(DT, OUTPUT);
digitalWrite(DT,HIGH);
digitalWrite(SCK,LOW);
Count=0;
pinMode(DT, INPUT);
while(digitalRead(DT));
for (i=0;i<24;i++)
digitalWrite(SCK,HIGH);
Count=Count<<1;
if(digitalRead(DT))
Count++;
Count=Count^0x800000;
return(Count);
pinMode(SCK, OUTPUT);
pinMode(sw, INPUT_PULLUP);
lcd.begin(16, 2);
lcd.print(" Weight ");
lcd.setCursor(0,1);
lcd.print(" Measurement ");
lcd.clear();
calibrate();
count= readCount();
int w=(((count-sample)/val)-2*((count-sample)/val));
lcd.setCursor(0,0);
lcd.print("Measured Weight");
lcd.setCursor(0,1);
lcd.print(w);
lcd.print("g ");
if(digitalRead(sw)==0)
val=0;
sample=0;
w=0;
count=0;
calibrate();
 if (HX711.get_units() >= 1)
   digitalWrite(13, HIGH);
  else {
       digitalWrite(13, LOW);
void calibrate()
lcd.clear();
lcd.print("Calibrating...");
lcd.setCursor(0,1);
lcd.print("Please Wait...");
for(int i=0;i<100;i++)
count=readCount();
sample+=count;
sample/=100;
lcd.clear();
lcd.print("Put 100g & wait");
count=0;
while(count<1000)
count=readCount();
count=sample-count;
lcd.clear();
lcd.print("Please Wait....");
delay(2000);
count=readCount();
val+=sample-count;
val=val/100.0;
val=val/100.0; // put here your calibrating weight
lcd.clear();
When I compile it shows this error
error: expected primary-expression before '.' token
So, At the end when I compile it show error in this section:-
  else {
Hope somebody helps me :slightly_smiling_face: :slightly_smiling_face:
6 posts were merged into an existing topic: Arduino uno Loadcell “if statements error”
