Load cell, GSM module
Dear All,
First of all I would like to thank you for reading my post.
I want to build a digital scale, using a load cell ( up to 100 kgr), height 1,2,3... times a day
and sent the results with a sms txt msg. The whole system to work on AAA batteries.
On top of that I want to be able to connect various sensors as well.
Do we have to use an amplifier or noise cleaner for the load cell (maybe 4 capacitors) ?
How long you think the batteries can last if you do one measurement per day and sent out only 1 sms on 2 AAA batteries?
My concern is, as being new to arduino, the power consumption, which parts to use, and if there
is an open source code for something similar.
Regards
we definitely have to use an amplifier for the load cell or connect it straight to analogue in?
mcp3551 will do the trick and work fine with arduino?
Thanks
Tried Google?
hx711 load cell (with or without "arduino")
arduino power consumption
arduino sleep
battery amp hours
etc etc etc
Dear Evans,
Yes I tried google thanks for your suggestion
