Load Cell, need recommendation on my project
On last attempt, i made a huge mistake with my Arduino UNO, 1KG load cell and, HX7111 Amplifier where my soldering quality was really-really bad.
But now the build (Weight sensor) is working after major revamps and tweaks, so here's my question:
  1. My sensor will refresh every 300miliseconds in the loop and I can see the measurement seems to be flactuating (in minute amount) Eg: 160.1g and sometime 160.3g (probably because of wind interference from ceiling fan?) . So how can I check within the loop, if the weight is consistent after 5 readings (300milisecs) then the system will play a buzzer?
  2. I already bought a wifi module and my goal is to once the buzzer goes on, the code will then get the value and send it to a PHP file and Database. I plan on creating a dashboard using PHP where all stored weight can be seen there in my index.php file. Is there any good tutorial you can recommend?
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/arduino-load-cell-hx711/
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
// Calibrating the load cell
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 4;
const int LOADCELL_SCK_PIN = 5;
HX711 scale;
  Serial.begin(57600);
  scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
  if (scale.is_ready()) {
    scale.set_scale();
    Serial.println("Tare... remove any weights from the scale.");
    delay(5000);
    scale.tare();
    Serial.println("Tare done...");
    Serial.print("Place a known weight on the scale...");
    delay(5000);
    long reading = scale.get_units(10);
    Serial.print("Result: ");
    Serial.println(reading);
  else {
    Serial.println("HX711 not found.");
//calibration factor will be the (reading)/(known weight)
#include <Arduino.h>
#include "HX711.h"
LiquidCrystal_I2C lcd(0x27, 16, 2);
HX711 scale;
  Serial.println("HX711 Demo");
  Serial.println("Initializing the scale");
  Serial.println("Before setting up the scale:");
  Serial.print("read: \t\t");
  Serial.println(scale.read());      // print a raw reading from the ADC
  Serial.print("read average: \t\t");
  Serial.println(scale.read_average(20));   // print the average of 20 readings from the ADC
  Serial.print("get value: \t\t");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight (not set yet)
  Serial.print("get units: \t\t");
  Serial.println(scale.get_units(5), 1);  // print the average of 5 readings from the ADC minus tare weight (not set) divided
            // by the SCALE parameter (not set yet)
  scale.set_scale(895.640);
  //scale.set_scale(-471.497);                      // this value is obtained by calibrating the scale with known weights; see the README for details
  scale.tare();               // reset the scale to 0
  Serial.println("After setting up the scale:");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight, set with tare()
  Serial.println(scale.get_units(5), 1);        // print the average of 5 readings from the ADC minus tare weight, divided
            // by the SCALE parameter set with set_scale
  Serial.println("Readings:");
  lcd.begin();
  //lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("Welcome");
  lcd.setCursor(0, 1);
  lcd.print("3");
  lcd.print("Welcome.");
  lcd.print("2");
  lcd.print("Welcome..");
  lcd.print("1");
  delay(2000);
  lcd.clear();
  lcd.print("Suu Balm");
  lcd.print("Smart Sensor");
  delay(2000);
  lcd.clear();
  lcd.print("Ready: Please");
  lcd.print("remove bottle");
  delay(5000);
  float i = scale.get_units();
  if (i < 1)
    i = 0.00;
  lcd.clear();
      lcd.print("SB Smart Sensor");
      lcd.print("Vol = ");
      lcd.print(i,1);
      lcd.print(" g");
  delay(300);
//if value consistent after 5 readings, buzzer will play and LCD show measurement complete
//then it will upload the value (i) into Database that can be displayed using PHP file
//I know how code in PHP and have my own hosted DB as well (with a domain name) so i wont use XAMPP or WAMPP
Best,
Azree
You use some persistent memory and a threshold:
  static float average = 0.0; // smoothed average
  const float alpha = 0.5; // https://en.wikipedia.org/wiki/Exponential_smoothing
   const float threshold = 0.1 ; // adjust this
  if (i < 1)
    i = 0.00;
  float difference = i - average;
  average += alpha * difference; // move the average  towards the recent
  lcd.clear();
      lcd.print(i,1);
      lcd.print(" g");
      if( abs(difference) < threshold){
  delay(300);
Instead of the exponentially weighted moving average, you could keep a rolling set of measurements and do statistics on them, but I like the EWMA better.
You can always expect a small variation when you convert an analog value to a number.
What are the raw values? I'd suggest you just set a threshold under which variations will be ignored.
