Load Cell OpAmp
I'm using a 1kg Load Cell which I bought here near our place.
And i use this blog as a reference:
http://cerulean.dk/words/?page_id=42
in the place where I bought the loadcell, they don't have INA125P which is needed. That's why I bought a equivalence IC of this which is INA114P. I research the data sheet of INA125P and INA114P and base from this. I connect the Pin to INA114P. And use the Code:
int weight = analogRead(0);
Serial.print(weight);
But the problem is. The program only shows two outputs in the serial monitor. And it is if a large amount of weight is applied and when there is no weight or low amount of weight is applied.
Example Output if there is weight applied
50
51
52
51
50
51
51
51
52
Example Output if there is no weight applied
152
150
152
151
151
152
152
For your reference here is the connection that i made with my IC and loadcell.
Arduino Analog 0 -> pin 6 IC
Arduino 5v -> pin 7 IC
Loadcell (Red) -> 5V Arduino
Loadcell (Black) -> Gnd Arduino
Loadcell (Green) -> Pin 3 IC
Loadcell (White) -> Pin 2 IC
Resistor -> Pin 1 and 8 IC
Please Help me.And Thanks :slight_smile:
Few questions:
What voltage difference are you getting across the load cell at different weights?
What voltage are you reading on your IC output pin at the different weights?
Are you using the DIP packaging or the SOL packaging (different pin outs)?
based on the PIN outs it looks like you are using the 8 pin DIP package, please verify
If you can supply the above questions, we might be able to give you some more specific solutions.
50 ~ 0.24 volts (using a 5 volt reference on the ADC)
150 ~ 0.75 volts
your IC can't pull all the way to ground or Vcc, you want to try swapping the outputs on your load cell to the IC to make the voltage go more positive instead of negative with added weight and check your gain amounts.
Also it looks like the example blog changed the Vref for the ADC to internal setting Vref to 1.1 volts instead of the default 5V.
