Load Cell Programming
I want to use 4 separate Load Cells for 4 different weights but a single code which shows the different weight for each cell like cell1, cell2, etc...
So Please Help to make a single code for it..
Thanks in advance..
Here is the Code I'm using...
#include "HX711.h"
#define DOUT  3
#define CLK  2
float units;
float fixweight;
int LED=13;
int LED2=8;
HX711 scale(DOUT, CLK);
float calibration_factor = -96650;
  pinMode(LED,OUTPUT);
  pinMode(LED2,OUTPUT);
  Serial.println("Press T to tare");
  scale.set_scale(-920);
  scale.tare();
  Serial.print("Weight: ");
  units = scale.get_units(), 3;
  if (units < 1.00 && units > -1.00)
    units = 0.00;
  Serial.print(units);
  Serial.println(" grams");
  if (units<=fixweight*0.2)
    Serial.print("Low Can: ");
    Serial.println(fixweight-units);
    digitalWrite(LED,HIGH);
    digitalWrite(LED,LOW);
    if (units>fixweight)
    Serial.print("Over Weight: ");
    Serial.print(units-fixweight);
    digitalWrite(LED2,HIGH);
    digitalWrite(LED2,LOW);
  if (Serial.available())
    char temp = Serial.read();
    if (temp == 't' || temp == 'T')
      scale.tare();  //Reset the scale to zero
    if (temp == '1')
      fixweight = units;
    Serial.print("FixWeight: ");
    Serial.print(fixweight);
 if (temp == '2')
then you have to create 4 instances(objects)
HX711 scale1(DOUT1, CLK1);
HX711 scale2(DOUT2, CLK2);
HX711 scale3(DOUT3, CLK3);
HX711 scale4(DOUT4, CLK4);
Take a look at multiple load cells
Thank You All I got the resolution with your help....
