Load Cell + RTC
Hello Fellas;
Hope you´re doing great.
So im doing a project wich uses a load cell and an rtc, and i´ve got into this problem:
void SERVO(){
if (units < pesoMinimo && exatashoras == true)
while (units >= pesoLimite){
digitalWrite (led432, HIGH);
units = scale.get_units(), 10;
else if (units >= pesoLimite){
digitalWrite (led432, LOW);
so my problem is thati have to do 2 comparations between units (wich is the weight onto the load cell) and between a value that is totally programable by the user (pesoMinimo). I still have that “exatashoras” wich is a condition that everytime the minutes in the rtc are pair, i recive 1.
What i wanted to happen here is if the units are < then the minimum value and the minutes are pair, then, until the units are >= than the maximum value (pesoLimite), the led432 wouldn´t stop “shinning”. It would only stop, if units get >= then the maximum value.
Rly hope you could help me.
Your question is not making a contribution to the old Thread where you have posted it so I have suggested to the Moderator to move it to its own Thread.
I think your problem is that your ELSE clause will trigger if either of the tests in the IF clause fails.
I’m not sure that I understand your description but I think you need to separate the time check from the weight check - maybe something like this. However your code snippet does not show how exatshoras is set so I may have got things all wrong. If you want more help please post the complete program.
And shouldn’t the WHILE be < rather than >=
if (exatashoras == true) {
   okToTestForWeight = true;
if (okToTestForWeight == true) {
   if (units < pesoMinimo)
    while (units < pesoLimite){
…R
@J0hnyKidCarcassas, do not hijack. Thread split as requested.
Considering the age of the old Thread I would not consider it a hijack - more like taking a room in an abandoned hotel :)
...R
