Load Cell with servo control
I have a loadcelll, 2 LCD I2C, ISL29125 sensor, HX711, and servo with button without keypad. When I can to detect from ISL29125 sensor, they will be classification in true or false then value ISL visible after push the button 5 times and average the value.
I want float z read from the classification, with the result that z will open and close the servo in condition 200 gr, 175 gr, 150 gr, 125 gr, etc.
What can I do with the code ?
load_cell.ino (10.1 KB)
@Chasni2218, do not hijack. Do not cross-post. Other post removed.
Chasni2218:
You can post it in code tags. I can't open .ino on my phone.
I’m sorry, i’m a newbie in here !! :sweat_smile:
#include <Wire.h>                  // deklarasi program
#include <LCD.h>                   // deklarasi lcd
#include <LiquidCrystal_I2C.h>     // deklarasi I2C
#include "SFE_ISL29125.h"          // deklarasi sensor ISL29125
#include "HX711.h"                  // deklarasi Load cell
#include <Servo.h>                  // deklarasi servo
#define DOUT A1
#define CLK A0
HX711 scale(DOUT, CLK);
Servo myservo;
LiquidCrystal_I2C   lcd1(0x26, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);       // Masukkan alamat Device 0x27, ukuran LCD 16x2 (dengan 16 pin)
LiquidCrystal_I2C   lcd2(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);       // Masukkan alamat Device 0x27, ukuran LCD 16x2 (dengan 16 pin)
const int  tombol1 = 8;    // Tombol Counter
const int  tombol2 = 9;    // Tombol Reset
const int  tombol3 = 13;     // Tombol Buka
const int  tombol4 = 12;     // Tombol Tutup
const int  tombol5 = 11;     // Tombol Reset
int freq = 0;
int ratarata = 0;
int CounterTbl = 0;
int STombol1 = 0;
int STombol2 = 0;
int STombol3 = 0;
int STombol4 = 0;
int STombol5 = 0;
int STerakhir = 0;
float z;
Int pos = 0;
float calibration_factor = 225.5; //This value is obtained using the SparkFun_HX711_Calibration sketch
SFE_ISL29125 RGB_sensor;
int Red = 0;
int Green = 0;
int Blue = 0;
unsigned int frequency = 0;
int data1 = 0;
int data2 = 0;
int data3 = 0;
int data4 = 0;
int data5 = 0;
int counter = 0;
boolean bhasil;
unsigned long i,                       // premenna cyklu
              cislo=2,                 // cislo, ktore testujeme, ci je prvocislo
              n=1;                     // poradie vypisovaneho prvocisla
boolean prime=1;                       // 0-false, 1-true
  bhasil = false;
  pinMode(tombol1, INPUT);
  pinMode(tombol2, INPUT);
  pinMode(tombol3, INPUT);
  pinMode(tombol4, INPUT);
  pinMode(tombol5, INPUT);
  lcd1.begin(16,2);                    // lcd.setBacklightPin(3, POSITIVE);
  lcd1.setBacklight(HIGH);
  lcd2.begin(16,2);
  lcd2.setBacklight(HIGH);
  myservo.attach(10);
    lcd1.setCursor(0,0);
    lcd1.print("    V-Macfer     ");
    lcd1.setCursor(0,1);
    lcd1.print("     READY!     ");
    delay(2000);
    scale.set_scale(calibration_factor);
    scale.tare();
    lcd2.setCursor(3,0);
    lcd2.print("Berat(gr)");
    //-------------------------->>>> RGB Sensor
    RGB_sensor.init();
Reply #3 has a large and unweildy loop() function and nothing else. Reply #4 has only part of the setup() function.
Use the control-T auto format before posting again.
Are there someone can help my script problem, please
  z = (scale.get_units());          // nilai z merupakan "nilai berat"
  lcd2.setCursor(5,1);
  lcd2.print(scale.get_units());
          //--------------------------->>>> Read sensor values (16 bit integers)
                  unsigned int Red = RGB_sensor.readRed();
                  unsigned int Green = RGB_sensor.readGreen();
                  unsigned int Blue = RGB_sensor.readBlue();
                  float R = RGB_sensor.readRed();
                  float G = RGB_sensor.readGreen();
                  float B = RGB_sensor.readBlue();
                  frequency = G-R;             // reading frequency
           if (bhasil == false){
                    lcd1.clear();
                    lcd1.print("GREEN:");
                    lcd1.setCursor(8, 0);
                    lcd1.print(frequency);     // printing GREEN color frequency
                    lcd1.setCursor(15, 0);
                    lcd1.print(CounterTbl);
                    lcd1.setCursor(0, 1);
                    lcd1.print(" AVG :");
                    lcd1.setCursor(7, 1);
                    lcd1.print(ratarata);
                    Serial.println ("Mode Monitoring");
                 if (frequency <= 15 || frequency >= 70) {   // 8  1700-200 Kg/Ha
                      lcd1.clear();
                      lcd1.setCursor(0, 0);
                      lcd1.print("Letakkan Daun" );// printing GREEN color frequency
                      lcd1.print("Pada Sensor.....");// printing GREEN color frequency
  // Baca Status Tombol
  STombol1 = digitalRead(tombol1);
  STombol2 = digitalRead(tombol2);
  // Jika Tombol Reset maka reset Counter
  if (STombol2 == HIGH) {
    Serial.println("Reset Data");
    delay(250);
    CounterTbl = 0;
    freq = 0;
    ratarata = 0;
    bhasil = false;
    lcd1.clear();
  //------------------------------->>> Baca Status Tombol Terbuka
  STombol3 = digitalRead(tombol3);
   if (STombol3 == HIGH) {
      myservo.write(90);
      myservo.write(0);
//------------------------------->>> Baca Status Tombol Tertutup
  STombol4 = digitalRead(tombol4);
   if (STombol4 == HIGH) {
      myservo.write(0);
      myservo.write(90);
//------------------------------->>> Baca Status Tombol Reset
  STombol5 = digitalRead(tombol5);
   if (STombol5 == HIGH) {
      lcd2.clear();
      delay(250);
      scale.tare();
  if (STombol1 == HIGH )  {
       CounterTbl++;
       freq = freq + frequency;
       ratarata= freq/CounterTbl;
       delay(250);
  if (STombol1 != STerakhir) {
     if (CounterTbl >= 5) {
         ratarata = freq/5 ;
         Pos;
         bhasil= true;
         STerakhir = STombol1;
          if (bhasil == true){
                if (ratarata  >=15  and ratarata <= 23)  {         // <1 1700-200 Kg/Ha
                    lcd1.print("AVG GREEN:");
                    lcd1.setCursor(12, 0);
                    lcd1.print(ratarata);         // printing GREEN color frequency
                    lcd1.print("P: 200 gram");
                    pos = 0;
                    myservo.write(pos);
                    If (z >= 200) { myservo.write(90) }
                } else if (ratarata >=24  and ratarata <= 28) {   // 2  1700-200 Kg/Ha
                    lcd1.print("P: 175 gram");
                    pos = 0;
                    myservo.write(pos);
                    If (z >= 175) { myservo.write(90) }
                } else if (ratarata >= 29 and ratarata <= 33) {   // 3 1700-200 Kg/Ha
                    lcd1.print("P: 150 gram");
                    pos = 0;
                    myservo.write(pos);
                    If (z >= 150) { myservo.write(90) }
                } else if (ratarata >= 34 and ratarata <= 38) {   // 4  1700-200 Kg/Ha
                    lcd1.print("P: 125 gram");
                    pos = 0;
                    myservo.write(pos);
                    If (z >= 125) { myservo.write(90) }
                } else if (ratarata >= 39 and ratarata <= 43) {   // 5  1700-200 Kg/Ha
                    lcd1.print("P: 100 gram");
                    pos = 0;
                    myservo.write(pos);
                    If (z >= 100) { myservo.write(90) }
                } else if (ratarata >= 44 and ratarata <= 48) {   // 6  1700-200 Kg/Ha
                    lcd1.print("P: 75 gram");
                    pos = 0;
                    myservo.write(pos);
                    If (z >= 75) { myservo.write(90) }
                } else if (ratarata >= 49 and ratarata <= 52) {
                    lcd1.print("P: 50 gram");
                    pos = 0;
                    myservo.write(pos);
                    If (z >= 50) { myservo.write(90) }
                    } else if (ratarata >= 53 and ratarata <= 70) {
                    lcd1.print("P: 25 gram");
                    pos = 0;
                    myservo.write(pos);
                    If (z >= 25) { myservo.write(90) }
                CounterTbl = 0;
                freq = 0;
                ratarata=0;
MorganS:
Can you help me, please ?
Why the servo is not move close or detect ratarata ?
Don't use numbers. Use names. Use the names you used in the comments on the right.
You read z from the scale and then you change the calibration on the scale and read it again to print a different value. So you have no idea what is in z.
Do you ever change the calibration back before the next reading of z?
                    lcd1.clear();
You read the color sensor and do some calculation with green and red. Then you examine the value of another variable unrelated to that calculation and print a color? I could not find where bhasil was given any value.
The code is still too fragmented to do much analysis. These 3 things are not the only problems.
