How do I connect two four-wire load cells to the HX711
Please help.
Please help.
Best guess, based on the very limited information provided: by soldering two wires to each of two load cells. Four wires, two load cells, and it's connected.
What load cell?
If the loadcell is a raw strain gauge with 2 pairs of outputs then you would use a Half-Bridge circuit.
Please help.
No experience with this, but I would just connect the two in parallel.
Load cell voltages should average each other.
Leo..
TECHNO_TEACHER:
How do I connect two four-wire load cells to the HX711Please help.
Have you really just repeated your question word for word? E.g. instead of answering the questions you where asked? I hope you are not really a teacher ...
What is the model number of the load cell?
If those ar two identical cells:
Cell A : red +V , black -V
Cell B : red -V , black +V
Signal cables to inputs (A or B) on HX711 (polarity doesn't matter)
As we dont know exactly info about your cells.. Check datasheet for color coding
@knut_ny
Two 4-wire load cells have four signal wires.
Leo..
sorry... didnt see the white wire in OPs drawing
connect cells parallel
red: +V , black -V
signals cables (also parallel) to port A
I do not understand the answers that English is not my first language.
Could you please explain by drawing on my project project
picture link:
loadcells connection
knut_ny:
picture link:
Thank you so much my friend
knut_ny:
picture link:
I used this configuration and obtained good results. However, I did some adjustments to enhance the accuracy of my system. Thanks!
