Load Program Data from sd Card?
Hey there, Just a short question, is it possible to search & load some Data from a sd card (using arduino library)?
I.e. I add some switches and lights and name them. They need an ID in EEPROM, and if you navigate to a menu point, it searches the ad card file line with the right ID and loads / showed the name of this switch in LCD?
I cannot use static names, cause the switches can be added or removed.
Yes, that is possible.
Ehm. Cool. You got a way for that? Or a link? It's not descriped on library's reference. Or just a tip how to start?
Break your problem down into discrete steps. There will be no single library to do everything you want.
