And set the fuse brown out voltage , and set it for 8mhz extranal xtal.
If you get it wrong you can just re change the settings after.
But it all depends on what xtal mhz , chip etc.
No , I think if you have a isp programmer , I dont think you can brick it. Ive installed the bootloader on 3 168 chips so far and loaded a hex file direct to the chip so cutting of the need of the boot loader, which frees up 2 extra k
Here are the relevant fuses, as shown in AVRStudio:
No , I think if you have a isp programmer , I don`t think you can brick it.
Nope, with just an ISP programmer, you can 'brick' an ATmega. The easiest way is choosing an impossible oscillator setting or disabling SPI. (Notice above how AVRStudio can't alter this value in ISP mode.)
I ask in avrfreaks and all answers were that I only can reset this fuse using a Higth Voltage programmer.
Conveniently, the AVR-Dragon IS a high voltage programmer.
