load variables line per line
Hi People,
I need help to load variables from certain line in SD card text, I have a text EXACTLY like:
reg001    i32.60  j5
reg002    i60     j2
reg003    i100   j12
I need a way to assing the values in text in variables, like:
READ LINE 1 and write in variable reg=1, and i=32.60, j=5.
(do the rest of alghotim)
READ LINE 2 (...).
Thaks for who can help, and sorry for my bad english. XD
First, you need to read from the SD card, and store in an array, all the characters that make up a record. Do you have code to do that?
Next, you need to parse the stored data. If you can change the format of the data, parsing can be easy. If not, parsing is going to be harder. Can you change the format?
reg=001, i=32.6, j=5
would be simpler to parse. Look for the commas to get the tokens, like "reg=001", "i=32.6", and "j=5". Then, parse each token to get the name and value (as string). Finally, convert the value as string to a value, and store it in the correct variable based on the name token.
PaulS:
The code is make up in C++ program in a computer and stored on SD.
I can´t change the format =(
I will try, thanks :wink:
