Loading a "long" value into eeprom?
#include <EEPROM.h>
long f1; //f1 will equal 7123456
byte buf[4];
buf[0] = byte (f1);
buf[1] = byte f1 >> 8;
buf[2] = byte f1 >> 16;
buf[3] = byte f1 >> 24;
This give the following errors,
long_to_4_bytes:7: error: expected constructor, destructor, or type conversion before ‘=’ token
long_to_4_bytes:8: error: expected constructor, destructor, or type conversion before ‘=’ token
long_to_4_bytes:9: error: expected constructor, destructor, or type conversion before ‘=’ token
long_to_4_bytes:10: error: expected constructor, destructor, or type conversion before ‘=’ token
Any suggestions?
Any suggestions?
Executable code must be in a function. The first line's use of byte is unnecessary. The other three uses are wrong.
You could address the issues that PaulS lists and get your current approach working, but I suggest you look at EEPROMWriteAnything for a much easier approach.
buf[0] = byte (f1);
What computer language do you suppose this is ?
