Operating system: Windows 7 Home premium SP1 64 bits
Board: Arduino Duemilanove with ATmega328
Problem: Can not load sample DF RobotShop rover Arduino program to board through USB cable
Additional info: Robot can run default loaded program (move front and back), 6 LED's turn on when connected to the PC with the USB, tried both pins 1/0 (light and temperature sensors) connected and disconnected.
I am trying to load the sample code Arduino code for the DF RobotShop rover. I downloaded the Arduino software from www.arduino.cc , as the PDF manual suggested. I connected the rover board to the PC with the USB cable. The device appears under "other devices" in the device manager.
In the "Update driver software" device manager right click option, I pointed to the "drivers" dirctory from the Arduino software. That did not worked. Then I downloaded a Windows Vista FTDI driver from http://usbserialdrivers.com/ . The device manager was able to install the software but it did not worked either.
For all the attempts (mentioned above) to load the Aldruino program to the board within the Arduino IDE, the following Java exception is thrown. It says that I should set the "Tools->Serial Port", but this menu option is always greyed out (disabled); no matter how I tweek the GUI (including restarting various times with the device plugged in and not). A similar exception is thrown when trying to open the serial port monitor.
As mentioned in another thread of this forum, there does not seem to be a way in Windows 7 to associate a USB port to a COMx slot. I have never played with this mapping so probably I am missing something.
Has somebody tried to do a similar task (sending an Arduino program through its IDE in Windows 7)?
I would appretiate if somebody can tell me a working combination (Arduino IDE, driver version/link) or solution (e.g., COMx setting procedure).
Thanks
processing.app.SerialNotFoundException: Serial port 'COM1' not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.(Serial.java:153)
at processing.app.Serial.(Serial.java:91)
at processing.app.SerialMonitor.openSerialPort(SerialMonitor.java:204)
at processing.app.Editor.handleSerial(Editor.java:2390)
at processing.app.Editor$18.actionPerformed(Editor.java:668)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
