Loading I2C data into array
I am trying to use an ADXL345 to measure vibration, utilizing I2C and ADXL libraries along with SimpleTimer. I've verified that the ADXL345 is working properly, reading only the Z axis. My goal was to read every 50 milliseconds and input into an array that would hold the vibration waveform.
This code does NOT work;
AZ[k] = accel.getAccelerationZ(); k = k + 1;
Is there a way to store readings in an array?
Also, any way to search these forums for similar questions?
Thanks.
For what definition of work? If AZ is the same type as the value returned by accel.getAccelerationZ(), and k is within the bounds of the array, the the code DOES work, and your problem is elsewhere.
PaulS:
@OP
Referring to the above quote, we would like to see the full syntactical declaration of the variable AZ[k]. Tell us the data type (char, int, byte or float) for the items of the array AZ and also the data type of the value returned by the method accel.getAccelerationZ();.
