loading LEDs?
i want to make LEDs "load up" and then don't turn off until i press a button, how do i do that? code would be appreciated
thx//Anto2
What does that mean?
i mean that i got for example 8 LEDs that slowly light up one by one, then when all lights are on they stay on until i press a button then they restart.
int button = 3;
int led = 11;
pinMode(led, OUTPUT);
if(digitalRead(button)==HIGH)
  for(int i; i<255; i++)
     if(digitalRead(button)==LOW)
      analogWrite(led, i);
      delay(3);
  while(digitalRead(button)==HIGH)
    //Do nothing
  digitalWrite(led,LOW);
This should work for one LED.
Make sure you use a 10K pullup resistor with your switch:
Learn about pullup resistors at Pull-up Resistors - learn.sparkfun.com
Close.
No cigar.
anto2:
Given there are not eight PWM pins on a UNO, that could be tricky.
You could easily manage two LEDs using soft PWM, the rest on hardware.
i<=255
is that better @Groove?
Solder_Soldier:
i<=255
Nope
Only one led at a time needs to be fading. The others are either on or off. So you might as well do all the fading in software.
PaulRB:
My sentiments entirely.
I think that you would need to use an 8 bit shift register and pwm on the output enable pin while shifting 10000000 or 00000001 right or left respectively.
Solder_Soldier:
Why do you think you need extra hardware?
Solder_Soldier:
And you did not read reply #2, did you? :roll_eyes:
