Hey everyone, first post here, sorry if it's wordy,
I've been trying to find a cheap solution to a localisation problem I'm having with a grid-maze-solving robot. I need to know its XY position as using dead reckoning will give me serious errors.
My initial thoughts were to use active radio beacons, but this was quickly put to bed after I realised how much work and money would have to be invested into something that probably wouldn't even work. RFID is out of the question too as apparently beacons are hard to tell apart and also give inaccurate distances (i.e. signal strengths).
My next idea was to use LiDAR on a rotating axis to scan its environment and map it, then using some method of SLAM to navigate the maze, however this still leaves the problem of actually knowing the robot's position in order to correct any odometry errors.
I'm now at the point where I think combining a 2D LiDAR style of mapping with passive beacons located around the outside of the maze could potentially give accurate triangulation. My thinking is that if I could use IR diodes as beacons and a directional IR receiver on my robot I'd be able to triangulate my robot's position well. Another route is a LiDAR and large diameter beacons which would give 'spikes'. I'd be using a stepper motor in any case to know the rotational angle up to 1.8deg (at an average distance of 2m from beacons I'd imagine this is acceptable).
Here I've found another set of problems, however, as I can't find any IR receivers that are focussed enough; the best I can find is the Sharp GP2D series, giving a 60mm detection diameter at 80cm, not ideal. I can always make my own lens or house the receiver in a tube, however this still doesn't seem ideal. One more product that could be used is a CCD camera like IR Tracking Camera, however I'm not sure if an Arduino can handle this as it feels as though image processing is required?
Anyways, I was hoping that anyone who's done something similar like this or has experience in anything that I've mentioned could give me a couple pointers in the right direction. I'd happily do some testing myself however money's tight and I'd like to hold off on ordering a bunch of stuff until I know for certain my method can work.
Thank in advance!
EDIT: I realise that this maze problem can be solved using other methods (e.g. right hand technique, then algebraic simplification), however I plan on implementing a neural network to solve the maze once mapped so localisation is imperative.
