Location of temp files when building project.
As it stands the IDE puts the output temp files in C:\Users<username>\AppData\Local\Temp\arduino_build_132929
I need to be able to easily get at the generated .elf file to be able to generate an assembler listing.
Is there a way to force the IDE to put/copy the .elf file in a dir under the project folder??
TIA
Dave
You can add a build.path entry to your Arduino IDE preference file (open the preference dialog in the IDE and click on the preference file name). Close the IDE before opening and editing the file.
Oh, and don't forget to create the folder first.
