lock code, how to add instant clear code at wrong number
hi I got this code, and if lockcode is 1 2 3 4, and I start at 2 I want it to clear the code and make me start at 1 again
const int button1 = 2; //first button is on pin 8
const int button2 = 3; //second is on pin 9
const int button3 = 4; //third is pin 10
const int button4 = 5; //fourth is pin 11
const int button5 = 6; //third is pin 10
const int button6 = 7; //fourth is pin 11
const int LED[] = {14,15,16,17,18,19};
const int Red = 8; //red LED is on pin 4
const int greenLed = 9; //green LED is pin 12
void checkEntered1(int button);
int code[] = {1,2,3,4}; //the desired code is entered in this array,
                        //separated by commas
int entered[7]; //create a new empty array for the code entered by
                //the user (has 4 elements)
void setup(){ //run once at sketch startup
  Serial.begin(9600); //begin Serial
  pinMode(button1, INPUT_PULLUP); //button 1 is an input
  pinMode(button2, INPUT_PULLUP); //button 2 is an input
  pinMode(button3, INPUT_PULLUP); //button 3 is an input
  pinMode(button4, INPUT_PULLUP); //button 4 is an input
  pinMode(button5, INPUT_PULLUP); //button 3 is an input
  pinMode(button6, INPUT_PULLUP); //button 4 is an input
  pinMode(Red, OUTPUT); //the red LED is an output
  pinMode(greenLed, OUTPUT); // the green LED is an output
//  setupLights(); //run the setupLights routine
//  setupLights(); //run it again
 // delay(650); //delay (only for effect, :P not needed)
  digitalWrite(Red, LOW); //turn the red LED on
  for (int i = 0; i < 6;i++){ //work through numbers 0-3
    Serial.println(code[i]); //print each digit of the code
    Serial.println(entered[i]); //print each element of the entered[]
                                //array (this was for me to check that it
                                //started at 0
    pinMode(LED[i],OUTPUT);
void loop(){ //run repeatedly
  if (digitalRead(button1) == LOW){ //if button1 is pressed
    checkEntered1(1); //call checkEntered and pass it a 1
    delay(250);//wait, needed for correct functioning, otherwise
               //buttons are deemed to be pressed more than once
  else if (digitalRead(button2) == LOW){ //if button2 is pressed
    checkEntered1(2); //call checkEntered1 and pass it a 2
    delay(250); //wait
  else if (digitalRead(button3) == LOW){ //if button3 is pressed
    checkEntered1(3); //call checkEntered1 and pass it a 3
    delay(250); //wait
  else if (digitalRead(button4) == LOW){ //if button4 is pressed
    checkEntered1(4); //call checkEntered1 and pass it a 4
    delay(250); //wait
    else if (digitalRead(button5) == LOW){ //if button4 is pressed
    checkEntered1(5); //call checkEntered1 and pass it a 4
    delay(250); //wait
    else if (digitalRead(button6) == LOW){ //if button4 is pressed
    checkEntered1(6); //call checkEntered1 and pass it a 4
    delay(250); //wait
void checkEntered1(int button){ //check the first element of the entered[] array
  digitalWrite(LED[button-1],HIGH);
  if (entered[0] != 0){ //if it is not a zero, i.e. it has already been inputted
    checkEntered2(button); //move on to checkEntered2, passing it "button"
  else if(entered[0] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
    entered[0] = button; //set the first element as the button that has been pressed
    Serial.print("1: ");Serial.println(entered[0]); //for debugging
void checkEntered2(int button){ //check the second element of the entered[] array
  if (entered[1] != 0){ //if it is not a zero, i.e. it has already been inputted
    checkEntered3(button); //move on to checkEntered3, passing it "button"
  else if(entered[1] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
    entered[1] = button; //set the second element as the button that has been pressed
    Serial.print("2: ");Serial.println(entered[1]); //for debugging
void checkEntered3(int button){  //check the third element of the entered[] array
  if (entered[2] != 0){ //if it is not a zero, i.e. it has already been inputted
    checkEntered4(button); //move on to checkEntered4, passing it "button"
  else if (entered[2] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
    entered[2] = button; //set the third element as the button that has been pressed
    Serial.print("3: ");Serial.println(entered[2]); //for debugging
void checkEntered4(int button){ //check the fourth element of the entered[] array
  if (entered[3] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
    entered[3] = button; //set the final element as the button that has been pressed
    Serial.print("4: ");Serial.println(entered[3]); //for debugging
    delay(100); //allow time for processing
    compareCode(); //call the compareCode function
void compareCode(){ //checks if the code entered is correct by comparing the code[] array with the entered[] array
  for (int i = 0; i<6;i++){ //these three lines are for debugging
  if ((entered[0]==code[0]) && (entered[1]==code[1]) && (entered[2]==code[2]) && (entered[3]==code[3])){ //if all the elements of each array are equal
    digitalWrite(Red, LOW); // turn the red LED off
    digitalWrite(greenLed, HIGH); //turn the green LED on
    delay(1000); //wait for a bit
    digitalWrite(greenLed, LOW); //turn the green LED off
    for (int i = 0; i < 7; i++){ //this next loop is for debugging
      entered[i] = 0;
    loop(); //return to loop() (not really necessary)
  else { //if you (or the intruder) get the code wrong
    digitalWrite(Red,HIGH);
    digitalWrite(Red,LOW);
    Serial.println("Red OFF");
      entered[i] = 0;
  close_all();
void close_all(){
digitalWrite(LED[0],LOW);
digitalWrite(LED[1],LOW);
digitalWrite(LED[2],LOW);
digitalWrite(LED[3],LOW);
digitalWrite(LED[4],LOW);
digitalWrite(LED[5],LOW);
your code is expecting a proper number of digits to be entered in the correct sequence with appropriate timing. if the wrong number of digits is entered or a button is pressed too soon it will get out of sync and i see no way for it recover.
i would suggest that each iteration of loop check for any button being pressed and store that value in a buffer. The values in the buffer can be checked for the correct sequence of button presses when the correct number of buttons has been pressed. if an incorrect sequence is entered, the buffer is reset (the index for the next button pressed). if a button is not pressed within a period of time (~3 sec), the buffer is reset
