I want to protect my Arduino from cloning.
The most i can do against it, that is set the correct Fuses/Lock bit trough AVRDUDE on SPI port.
I got USBASP, Extreme Burner AVR, so i can set the Fuses/Lock bit's.
But i am totally confused in settings.
What i need to set? I want to prevent code downloading into hex file. If i disable it, can i upload a new code trough bootloader? Or i need to disable Bootloader to for fully safety?
Do i need to uncheck the "Serial program downloading (SPI) enabled; [SPIEN=0] *" line?
What sould i chose from the buttom menu? Disable LPM, SPM?
What's the different from this menu? Wich one i need to configure?
If you can write me the correct fuses/lock bit values for my needs, then i will be pleased!
I have Read a lot. Now i understood some thing, but i have some question.
So the methode is: We write a program in Arduino IDE. Then compiled program saved in .hex file on the local PC. I load this hex file with Extreme Burner AVR program, and i set the lock bit to 0x00, then burn the program.
In this case after we upload the program, the lock bit are set, so i cannot read eeprom and flash memory with AVRDUDE-like program. It's true?
When i write with ISP programmer and "Boot Reset vector Enabled (default address=$0000); [BOOTRST=0]" unchecked, then the bootloader automaticly deleted?
