I wanted to boost security on my shed door, and what better way with an Arduino-powered combination lock?
The pictorial build log for this project can be found over here: http://madmodder.net/index.php?topic=2858.0 The main emphasis on that thread is the machining work…
Fortunately, the combination lock code is very simple. Mark Stanley & Alexander Brevig already created the Matrix Keypad code (http://www.arduino.cc/playground/Code/Keypad), so all I needed to do was modify their code a little to parse the keyboard in the way I wanted; and to add the code which builds the combinations up & tests them.
The code is ugly… it’s my first effort at Arduino code, and whilst I’ve been a BASIC programmer (up to & including MS Visual Basic.NET), C has always remained slightly out of reach… Lucky the Arduino’s version of C doesn’t seem to have any of the mega-steep learning curve associated with regular C (or C++)… not that my string handling is very elegant. e.g. How could I improve it to cope with variable-length codes?
The code exceeds the max posting size, so I’ll have to split it over 2 posts… here’s part 1:
/* @file Combination_Lock.pde
|| @version 1.0
|| @author Ade Vickers
|| @contact javickers@solutionengineers.com
|| @description
|| | Based on keypad.h amongst others. Drive a combination lock
|| | using a 16-key keypad. Secret codes are hard-coded below.
|| | Thanks to Alexander Brevig/Mark Stanley for the Keypad library
#include <Keypad.h>
#include <Servo.h>
// Define keyboard
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {6,7,8,9}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {2,3,4,5}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// Pins used for LEDs and the servo
byte attnPin = 12;
byte errorPin = 13;
byte lockOperatePin = 10;
byte lockIndicatePin = 11;
// Status and timer variables
boolean haveAttention = false; // True after "A" is pressed to get the machine's attention
byte loseAttentionIn = 0; // Used as a counter
const byte ATTENTION_SPAN = 50; // Approx 5 seconds
boolean haveError; // Problem with the combination (if true, red light is on)
byte loseErrorIn = 0; // Clear error timer
boolean lockOperate; // Lock is open (active)
byte lockDeOperateIn = 0; // Used as a counter, ala loseAttentionIn
char myCode[5] = "0000"; // Starting point for the code
char* myComp[] = { "1234", "5678", "9012" }; // The secret codes the machine will recognise
const byte NUM_CODES = 3; // How many are there [I shouldn't need this...]
// Lock servo
Servo lockServo;
const int LOCK_CLOSED = 25; // Servo sits at 25 degrees when "inactive"
const int LOCK_OPENED = 71; // 71 degrees happens to be the sweet spot for the lock to be open
void setup(){
Serial.begin(9600); // Debugging via serial port
pinMode(attnPin, OUTPUT); // Prepare the output pins (these all connect to the LEDs)
pinMode(errorPin, OUTPUT);
pinMode(lockIndicatePin, OUTPUT);
digitalWrite(attnPin, HIGH); // Flash all LEDs on & off in sequence, tells me the lock is initialized.
delay(50);
digitalWrite(errorPin, HIGH);
delay(50);
digitalWrite(lockIndicatePin, HIGH);
delay(250);
digitalWrite(attnPin, LOW); // Initialize to waiting state
delay(50);
digitalWrite(errorPin, LOW);
delay(50);
digitalWrite(lockIndicatePin, LOW);
// Attach the servo and move to position 0
lockServo.attach(lockOperatePin);
lockServo.write(LOCK_CLOSED);
// Not waiting for a code yet
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
char key = keypad.getKey(); // Read the keypad
int i;
if (key != NO_KEY) { // Assuming a key is pressed...
switch (key) {
case 'A':
Serial.print("A "); // For debugging purposes, output the button pressed.
case 'B':
Serial.print("B ");
case 'C':
// Handled in "press"
Serial.print("C ");
case 'D':
Serial.print("D ");
if (haveAttention) { // If we have attention, then check for codes
boolean match = false;
for(i=0;i<NUM_CODES;i++) {
Serial.print(myComp[i]); // Debugging - I was having trouble with strcmp
Serial.print(" ");
Serial.println(myCode);
if (strcmp(myComp[i], myCode) == 0)
match = true; // One of the codes matched; set match = true
if (match) {
// Unlock code
setStatus(0,0,255); // Operate the lock
// Error code
setStatus(0,255,0); // Display an error
default:
// Any other key, add it to the code. We roll the code forwards and add the char at the end...
// The code could include # and * characters, although none of them do
loseAttentionIn = ATTENTION_SPAN; // Reset the attention counter
for(i=1;i<4;i++) // Scroll the code in the code buffer;
myCode[i-1] = myCode[i]; // i.e. "1234" becomes "2344"
// Append the new code // Replace the 4th char with the new char
myCode[3] = key; // i.e. if 5 was pressed, "2344" becomes "2345"
// Blink the attention light to register the keypress
digitalWrite(attnPin,!haveAttention);
delay(30);
digitalWrite(attnPin,haveAttention);
// Wait 100ms, then do additional processing
delay(100);
// Attention timer
if (loseAttentionIn > 0) {
loseAttentionIn--;
if (loseAttentionIn == 0) {
setStatus(0,1,1); // Change attention status to "don't have attention"
// Error timer
if (loseErrorIn > 0) {
loseErrorIn--;
if (loseErrorIn == 0) {
setStatus(1,0,1); // Put error lamp out, if it's on.
// Lock operate timer
if (lockDeOperateIn > 0) { // If the lock is currently operating...
lockDeOperateIn--;
if (lockDeOperateIn == 0) {
setStatus(1,1,0); // Switch lock operator off
