I bought a TM1638 Display Module with Common Anode 8 LED with 16 Buttons. I seem to have run into some sort of limitation on the math I am doing in the sketch that reads the buttons and displays the numbers.
First, I don’t recommend this module for a couple of reasons.
- The quad LED devices are common anode, rather than common cathode that Ricardo Batista’s tm1638-library-master is written for.
- I think that library also is limited to decoding 8 buttons.
I was able to overcome those limitations by using the modifications to the standard library posted by 1958Brian here: TM1638 display Common Anode 8 LED with 16 buttons - Using Arduino / Displays - Arduino Forum
The sixteen buttons return values that are powers of 2. And they are not in one sequence. Odd powers of 2 are returned by the first two rows, and even powers of 2 by the third and fourth rows. The highest returned value is 32,768. To convert those returned values to numbers from 0 to 15, I computed the log base 2 of the returned value. I then used that converted number as an index of an array of values as a key map.
Here is the problem. The natural log(returned value) function seems to return the correct value. But when I calculate the log base2 of 16,384 and 32,768 I get the same result: the correct answer for 16,384.
Here is my code. It is a snippet of the actual sketch without the LED handling:
uint16_t keyindex;
//long keyvalues[] = {8, 0, 9, 1, 10, 2, 11, 3, 12, 4, 13, 5, 14, 6, 15, 7};
long keyvalues[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16};
long powersOfTwo[17] = {1, 2, 4, 8, 16, 32, 64, 128, 256, 512, 1024, 2048, 4096, 8192, 16384, 32768};
uint16_t key; // the pressed key value - each key is 1 bit in this unsigned int
float currValue = 0;
currValue = 0;
// Loop through each of the possible key values
for (int i = 0; i <= 15; i++) {
key = powersOfTwo[i];
Serial.print("Key pressed: ");
Serial.print(key);
Serial.print(" - log (key): ");
Serial.print(log (key));
keyindex = log (key) / log (2);
Serial.print(" - keyindex: ");
Serial.print(keyindex);
currValue = currValue * 10 + keyvalues[keyindex];
Serial.print(" - currValue: ");
Serial.println(currValue);
Here is the Serial Monitor debug results:
Key pressed: 1 - log (key): 0.00 - keyindex: 0 - currValue: 0.00
Key pressed: 2 - log (key): 0.69 - keyindex: 1 - currValue: 1.00
Key pressed: 4 - log (key): 1.39 - keyindex: 2 - currValue: 12.00
Key pressed: 8 - log (key): 2.08 - keyindex: 3 - currValue: 123.00
Key pressed: 16 - log (key): 2.77 - keyindex: 4 - currValue: 1234.00
Key pressed: 32 - log (key): 3.47 - keyindex: 5 - currValue: 12345.00
Key pressed: 64 - log (key): 4.16 - keyindex: 6 - currValue: 123456.00
Key pressed: 128 - log (key): 4.85 - keyindex: 7 - currValue: 1234567.00
Key pressed: 256 - log (key): 5.55 - keyindex: 8 - currValue: 12345678.00
Key pressed: 512 - log (key): 6.24 - keyindex: 9 - currValue: 123456792.00
Key pressed: 1024 - log (key): 6.93 - keyindex: 10 - currValue: 1234567936.00
Key pressed: 2048 - log (key): 7.62 - keyindex: 11 - currValue: ovf
Key pressed: 4096 - log (key): 8.32 - keyindex: 12 - currValue: ovf
Key pressed: 8192 - log (key): 9.01 - keyindex: 13 - currValue: ovf
Key pressed: 16384 - log (key): 9.70 - keyindex: 14 - currValue: ovf
Key pressed: 32768 - log (key): 10.40 - keyindex: 14 - currValue: ovf
(I'm not worried about the overflow yet)
