Hello Folks! So it turns out Software Serial is working fine in our tests. We thought it was broken because we were doing loopback tests and software serial can't receive at the same time as it sends data. Looking at your fritzing image above I've noticed that you have not connected the two ground pins of the Beans. You must connect devices to the same ground level if you want them to communicate (this goes for SPI and I2C as well).
I must be having a different problem. I am not sure what it is then. The same sketch I am using works an an Arduino Uno using the digital pins (That's why I assumed it was an issue on Bean).
Thanks.
