logarithms with floats?
I would like to use logarithms with a program I am writing but I don't understand the correct syntax for logarithms. I can't really find it easily so I figured I'd ask here.
for what I'm trying to do I basically want
log(base10)t = x
If logarithms can't be done is there an alternative way to do this?
They can. What is the real problem?
I don't understand the syntax for logarithm, that's the issue. I don't know how to tell arduino to do logarithms with base 10.
The syntax for logarithm is a function call that passes a float, and returns a float.
First hit on Google: http://www.techonthenet.com/c_language/standard_library_functions/math_h/log10.php
obito94: If logarithms can't be done is there an alternative way to do this?
The AVR LIBC contains two functions for calculating logarithms: http://www.nongnu.org/avr-libc/user-manual/group__avr__math.html#ga7f7d556ab6b6235777a179647c152126
The log() functions calculates the 'natural logarithm' and the log10() function calculates the 'decimal logarithm'.
jremington: First hit on Google: http://www.techonthenet.com/c_language/standard_library_functions/math_h/log10.php
The thing I don't understand here is
double log10(double x);
It seems that up here log10 is defined and uses "x" say for example I wanted to give "x" a value. If I do this then does that work?
double x=360;
  double log10(x);
If this is the case then what do I put for delay? I can't put "x" as "x" just equals 360
Yes.
No. That won't even compile.
  double x=360;
  double val = log10(x);
will compile. Whether val is even close to what you expect, or not, is anybody's guess.
I see your problem. You don’t understand parameter passing.
Forget about “x”. It’s a name that is internal to the function. It is outside the scope of the calling program (not visible to it). The value that you pass to log10() replaces x inside the function.
If you need the log of some number, say “ourNumber” and assign it to val, it would be like this:
val = log10(ourNumber);
