Hi Everyone
I have been using the sketch supplied with the logger shield(http://shieldlist.org/adafruit/logger) and it seems to work fine. I want to record the surface deflections on my rc aircraft. So i was planning to take a tap out of the servo potentiometers, but that would mean large wire lengths(about a meter) leading to the datashield. Is it good to transmit analog signals over this range?
I would also like to record pwm inputs from my radio and angular rates from a gyro(available as a digital signal). I see from shieldlists that the logger shield has pins A0-A3 free. What about the digital pins, could i use them to record these values. Wouldn't an elegant solution be to mux all these signals and send them to the logger shield?
I am an electronics noob and i need some help on this.
Thanks Sam
