Logging data from SparkFun Thermocouple to microSD in microSD Shield
Hey all! I am completely new to programming in Arduino, but it's necessary for a project I'm working on this summer. I searched for some information on this topic but I was unable to find any that made sense to me, or was exact to what I'm trying to do.
The components that I have working together are: Arduino Uno, SparkFun MAX31855K Thermocouple Breakout, SparkFun FTDI Basic Breakout 3.3V, Type K Thermocouple, and SparkFun microSD Shield.
I have all of those wired and soldered together using the SparkFun hook-up guide, and when utilizing the code they provide to go with the hook-up, I am able to get proper data to display in the Serial Monitor.
My next step would be to get that exact data to record to a microSD card so that I can collect and record data without being hooked up to a computer.
I've found code provided by Arduino about how to Read/Write to a microSD card, but I'm unable to figure out how to integrate that with my already-working sensor code.
Below is the code I have working for my sensor:
/**************** MAX31855K_Thermocouple_Digitizer_Example.ino *****************
 * MAX31855K Thermocouple Breakout Example Code                                *
 * brent@sparkfun.com                                                          *
 * March 26th 2015                                                             *
 * https://github.com/sparkfun/MAX31855K_Thermocouple_Digitizer                *
 * Use the "serial monitor" window to read a temperature sensor.               *
 * Circuit:        *
 * MAX31855K breakout attached to the following pins                           *
 *  SS:   pin 10                                                               *
 *  MOSI: pin 11 (NC)                                                          *
 *  MISO: pin 12                                                               *
 *  SCK:  pin 13                                                               *
 *  VCC:  pin 14                                                               *
 *  GND:  pin 15                                                               *
 * Development environment specifics:                                          *
 * 1.6.4        *
 * Arduino Pro Mini 328 3.3V/8MHz                                              *
 * This code is beerware; if you see me (or any other SparkFun employee) at    *
 * the local, and you've found our code helpful, please buy us a round!        *
 * Distributed as-is; no warranty is given.                                    *
#include <SparkFunMAX31855k.h> // Using the max31855k driver
#include <SPI.h>  // Included here too due Arduino IDE; Used in above header
// Define SPI Arduino pin numbers (Arduino Pro Mini)
const uint8_t CHIP_SELECT_PIN = 10; // Using standard CS line (SS)
// SCK & MISO are defined by Arduiino
const uint8_t VCC = 14; // Powering board straight from Arduino Pro Mini
const uint8_t GND = 15;
// Instantiate an instance of the SparkFunMAX31855k class
SparkFunMAX31855k probe(CHIP_SELECT_PIN, VCC, GND);
  Serial.println("\nBeginning...");
  delay(50);  // Let IC stabilize or first readings will be garbage
  float temperature = probe.readCJT();
  // Read methods return NAN if they don't have a valid value to return.
  // The following conditionals only print the value if it's not NAN.
  if (!isnan(temperature)) {
    Serial.print("CJT is (˚C): ");
    Serial.println(temperature);
  // Read the temperature in Celsius
  temperature = probe.readTempC();
    Serial.print("Temp[C]=");
    Serial.print(temperature);
  // Read the temperature in Fahrenheit
  temperature = probe.readTempF();
    Serial.print("\tTemp[F]=");
  // Read the temperature in Kelvin
  temperature = probe.readTempK();
    Serial.print("\tTemp[K]=");
  // Read the temperature in Rankine
  temperature = probe.readTempR();
    Serial.print("\tTemp[R]=");
  delay(750);
Any help would be greatly appreciated; thank you in advance! :slight_smile:
