Logging data to the USB Thumb Drive
I would like to modify SDDataLogger to write to a USB thumbdrive instead of SD card. Is it just a question of changing the filepath?
DannySwarzman:
Yes. Since "FILE_APPEND"
 File dataFile = FileSystem.open("/mnt/sd/datalog.txt", FILE_APPEND);
You might need create that file first.
touch /mnt/sd/datalog.txt
change filepath base your system.
http://wiki.openwrt.org/doc/howto/usb.storage
I've been experimenting. Apparently:
will create the file if it isn't there.
It seems the crucial part is :
mount -t vfat /dev/sda1 /mnt/usb
IN the OpenWrt document, there several examples of the mount command.
I'm not sure if the -t vfat part is needed. It applies to my thumb drive because that is how it was formatted. I suppose that other filesystem types are possible.
It seems that /dev/sda1 identifies a device and /mnt/usb is a path associated with that device.
There are still some mysteries. Such has how the directory /mnt/sd is associated with at device and the relationship between the various directories within /mnt.
I will experiment more to clarify these questions. In the meantime, it would be great if someone else who understands this better would respond.
