I want to log some data from a BMP280 and BNO055. I found some code online, but don't know how to use it! Could someone maybe walk me through what to do?
I think that the line: " ``` String dataString = "";
// read three sensors and append to the string:
" is important, but I don't know what to do.
Please let me know if anyone has some ideas!!
(Code link below)
https://www.arduino.cc/en/Tutorial/LibraryExamples/Datalogger
-Lucas Rozanski
Please Auto format your code in the IDE, select all of it, use Copy for forum in the IDE and paste it here so that it is in code tags to make it easier to read and copy for examination
SD card datalogger
This example shows how to log data from three analog sensors
to an SD card using the SD library. Pin numbers reflect the default
SPI pins for Uno and Nano models
The circuit:
analog sensors on analog ins 0, 1, and 2
SD card attached to SPI bus as follows:
** SDO - pin 11
** SDI - pin 12
** CLK - pin 13
** CS - depends on your SD card shield or module.
Pin 10 used here for consistency with other Arduino examples
(for MKRZero SD: SDCARD_SS_PIN)
created 24 Nov 2010
modified 24 July 2020
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 10;
// wait for Serial Monitor to connect. Needed for native USB port boards only:
while (!Serial);
Serial.print("Initializing SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("1. is a card inserted?");
Serial.println("2. is your wiring correct?");
Serial.println("3. did you change the chipSelect pin to match your shield or module?");
Serial.println("Note: press reset or reopen this serial monitor after fixing your issue!");
while (true);
Serial.println("initialization done.");
// make a string for assembling the data to log:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += ",";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
dataString += ",";
It is equivalent to below
// read first analog input
int sensor = analogRead(0);
dataString += ",";
// read second analog input
sensor = analogRead(1);
dataString += ",";
// read third analog input
sensor = analogRead(2);
So what you need to do is read you sensors and add the result to the String as shown in below pseudo code; and next you can save the String to file. Replace the .. by the actual reading of the sensors and assign the reading to the variables BMP280_result and BNO055_result.
